1980 SC won't start
I have spark from coil but no spark out of cap. I have the MSD, blaster coil, new cap, rotor and wires. What might cause this problem?
Old 05-12-2015, 12:12 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Only a couple of things to check.
Aside from parts, you sure you have the rotor snapped on tight?
What part number is your rotor?
1981 911SC Targa
Old 05-12-2015, 04:27 PM
Bob, is there anything with the distributor I can look at? Everything has checked out so far with coil check new cap and rotor. Great spark from coil when ignition is turnig.
Dan
Old 05-12-2015, 06:32 PM
Bob, is there anything with the distributor I can look at? Everything has checked out so far with coil check new cap and rotor. Great spark when ignition is turning.
Dan
Old 05-12-2015, 06:37 PM
