Cevan's Avatar
Heat backdate on a 3.2 question
I've searched here but can't find the specific info I need. I'm removing the heater blower on my '86 Carrera with stock exhaust. I've ordered the 930 duct from Parts Heaven. I'm assuming it requires a 2 1/2" hose on that end but the rubber sleeve that goes through the tin has an ID closer to 3".
What have people used for a reducer?
1986 Carrera coupe - black on black
1972 CB500/4
Old 05-28-2015, 06:55 AM
Yes it runs
tsiegwart's Avatar
Send a message via AIM to tsiegwart
https://tsiegwart.wordpress.com/2010/05/02/heater-backdate/
I got the hose from an aircraft supply company, did not need a reducer. i forgot the diameter, i can measure tonight.
Todd, Minneapolis
1987 Targa
TargaBlog http://tsiegwart.wordpress.com/
32C #4
Old 05-28-2015, 07:05 AM
For a reducer go to the Pegasus Racing website. Their collection of air hose reducers is the largest I have come across. To get the footwell blowers to work in the defroster mode you will have to modify the heater relay. A couple of threads on this forum have all the info.
Old 05-28-2015, 09:40 AM
Cevan's Avatar
Thanks hoss. I've seen those threads and will do that modification.
1972 CB500/4
Old 05-28-2015, 10:47 AM
Cheeck out post 30 on my backdate thread:
so this is how a backdate project starts...
Old 05-28-2015, 03:07 PM
A true hot air "backdate" uses parts and hot air paths that replicate or closely resemble those found on early 911s. Otherwise, it's just deleting the engine-mounted blower and channeling an air path from the engine shroud. Try this:
Tips & adivce needed for backdating heat
Note: Use google search with the search term, "pelicanparts XXXXXXXX" where XXXX is the topic. The search feature in internet forums isn't as robust as the major internet search engines.
Especially helpful if your question is along the lines of, "what oil should I use?"
Old 05-28-2015, 09:14 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by 911pcars View Post
A true hot air "backdate" uses parts and hot air paths that replicate or closely resemble those found on early 911s..."
And should look like this; More pics and details @ http://forums.pelicanparts.com/newreply.php?do=newreply&p=6119121
Who Will Live... Will See
Old 05-29-2015, 02:44 AM
