Hello all, Well as is obvious from last picture,it sleeps no more ! Thank so much to you all Tony,Ed,Ossiblue Rockreid and all. Now to do some checks and see that everything is working properly,even put the wheels on and move it! Will report back soon.Regards,Michael.
That's great. Hope it gives you years of enjoyment.
Good job!!!!!!
Michael,
You did all the work and you should get the credit for doing it well. All we did was share our different experiences with you. Enjoy driving the car now. Tony |
Hello everyone, It was all your input that got me on the right track sooner,thanks again. I will put some photos and some follow up reports when I get it out of it's pokey little hole. Michael. [Tyres,refit all the parts I had removed to convert it to right hand drive,will now leave it left hand drive,refit windscreen, registration,etc.....Michael.
Hello,another small snag, the replacement fuel pump is too big to fit where the original came from.Does anyone know the right order to assemble the original? {my mate dismantled it without noting how it went!] Regards,Michael.
Anyone have a photo of a test tank they used to start up a CIS motor ?
and has anyone built one that mounts where the stock tank sits so you can drive around the block for testing ? I normally run a gallon can of fuel with some cleaner in it , use a 12v pump and run it thru the fuel lines in the chassis , maybe 5 times to clean the old fuel junk out, add a LARGE fuel filter on the end and pump to another gallon car , repeat repeat repeat |
Michael
Well done for resurrecting the car. 20 yrs. I'm just in the process of starting my own CIS journey with my 76 sporto. So been reading up. I'm in Canberra, so wouldn't mind dropping past your place, for a bit of a chat if I don't get the car running sweet in the next cpl weeks. Sent you a pm. Cheers Michel |
If you choose to go this route, there are several ways to attach the pump to the beam. Do a search or ask directly as someone will surely post a link. |
Ossiblue, [has that got anything to do with Aus?] I was trying to keep as much as I could original on the '73, but what you say makes sense so I will have a look at that. I don't know how to look for a thread on the subject apart from looking at the lot! Thank you,regards,Michael.
Michael
Good to talk today - look forward to catching up. A couple of links to fuel pump relocation http://forums.pelicanparts.com/porsche-911-technical-forum/665379-power-relocated-fuel-pump.html#post6629047 |
This is a picture of the original fuel pump for a 73.5 in it's bracket.
http://forums.pelicanparts.com/uploa...1434714143.jpg |
Ed, Yes that is what I have and I would like to assemble it properly as it still goes,but need to assemble the plates in the right order. Regards,Michael.
Hello,,..Here is a photo of my pump, hope someone can give me some clues on how it should go back together. Looking at Ed's photo gives me a good start...Regards,Michael.
http://forums.pelicanparts.com/uploa...1434881050.jpg |
Ed...That link to the mfi pump will be handy if I need to go that far at a later date. The pump end is not like the cis pump at all so I have re-assembled mine as in your photo hoping it is in the working position.will now go and give it a try..Pity I have disconnected the gauges,but will see if car starts.....Regards,Michael.
Hello.....Well by duplicating the pump in Ed's photo [after my second proper look] I now have a running car on it's ORIGINAL pump.Guess who is happy.Thanks Ed. Regards,Michael.
Hi Michael tried to contact you a couple of times - give us a call when you can.
Cheers Michel (Canberra) |
Well it's been around the block twice and I just gave it it's first wash in 21 years! Michael.http://forums.pelicanparts.com/uploa...1438901112.jpg
http://forums.pelicanparts.com/uploa...1438901349.jpg http://forums.pelicanparts.com/uploa...1438901443.jpg http://forums.pelicanparts.com/uploa...1438901519.jpg |
Hello, Well it has been asleep (mostly) for another 8 years. I am now in the process of trying to get it going again. Will report back soon. Regards, Michael.
I see you haven't been to the forum in a few years.
Any luck getting it running again? |
| All times are GMT -8. The time now is 10:56 PM. |
