1986 911 Targa front Boge strut question
I am trying to replace the front strut cartridge inserts, however the struts on my car look like the entire strut has to be replaced as there does not appear to be a way to remove the strut cartridge insert. The strut is a Boge strut. Just above where the strut is attached to the wheel there is a retaining collar that looks like it is press fit to the cartridge that keeps the bottom of the cartridge in place (unlike the pin for a Bilstrien insert). I have seen on various parts websites that Boge struts have replaceable cartridge inserts. The cost difference is huge. $700 - $800 per strut about $135 per insert. Just not sure how they are replaced.
Slide your finger around the collar. If you feel a notch in the surface, it's for a thing called a spanner wrench or hook type wrench. Some inserts are held in the tube with this threaded collar. The rest have threads on the inserts. A lot of DIY owners simply remove with a pipe wrench. Block car, remove wheel, apply pipe wrench with cheater extension.
have owned/driven more than one Porsche |
The insert tubes have different threads depending upon the manufacturer.
Member 911 Anonymous
Can you post a pic.
Also make sure you read the BOGE part# to insure you get the correct insert, My PO swapped spindle assembly with a Club Sport, nice but messed my order up and had to return the correct OEM part for a proper part for the uped housing. Club Sport Spindle / Strut Assembly ![]() OEM -'85.5 Insert for Standard Spindle/Strut Assembly ![]() '86+ / Club Sport Insert
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Brew Master
You need to remove the nut in the "frunk" that holds the strut rod in place, loosen the gland nut (last pic posted by Draco. It will probably look different and depending on the year of your car it will either have internal or external threads. You'll need to loosen your tie rod nut and remove the tie rod from the control arm. Once you've done that, you pull down on the dust cap and compress the strut. Once the strut is compressed, you pivot it out of the wheel well and then pull the insert out of the strut housing. BE CAREFUL, you should put some tape and a blanket on your fender in the event you accidentally bump the strut into the fender.
I believe what you are calling the cartridge is actually your strut housing. The insert is inside the housing. Hope this helps. |
1986 911 Targa front Boge Strut Question
Here are the pictures. The picture of the new insert shows a round nut that came with it. Maybe it threads onto the strut housing to hold the insert in place. Not sure.
Look at the upper end of the strut. There should be a *large* cap threaded into the strut. The 22mm hex nut on the chromed rod end goes in the frunk.
Brew Master
Read this: http://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/63-Shocks/63-Shocks.htm It should clear things up for you. Last edited by cabmandone; 05-26-2015 at 11:13 AM.. |
