Wipers
Hi
Just removed the wipers form my 82 SC to paint them. On replacing them the wipers dont work - I can hear the motor running though. Is there an easy fix for this?
Old 04-18-2015, 07:56 AM
Oh Haha's Avatar
I assume you mean you removed the wiper arms.
If they are not seated all the way down on the stubs they will not move although the motor will turn the stubs.
Pacific Blue
Wayne
Old 04-18-2015, 08:24 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 ^^^ must be fully seated and locked. To test remove the new arms and see if stub moves when wiper is turned on.
'85 Carrera Targa
PCA/POC
Old 04-18-2015, 10:00 AM
universeman's Avatar
If the issue is (as above) they are not seated properly, make sure you clean off the threads on the studs & arms; the threads can get clogged with metal shavings from each other and you don't get positive engagement.
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 04-18-2015, 10:21 AM
Thanks for the answers guys. The problem was actually that the mechanism had become detached from the motor. To fix this, I had to remove the cover beneath the bonnet, followed by the blower assembly. There was then just about enough room to reposition the mechanism and tighten the nut and washer. Very fiddly and took about 3 hours.
But at least I have wipers lol!
Old 05-27-2015, 05:59 AM
