Kevin G.'s Avatar
Question Plug alternative for 2.2S w/mfi
Hey, all
I am about to go through the Check / Measure / Adjust procedures on my 2.2S MFI, and wanted to try an alternate plug.
I have been happy with the stock Bosch W3dpo so far, but now have an MSD unit which recommends a much wider plug gap. To date, I have not been able to figure out how to adjust the gap on the side-firing Bosch platinums, and am looking for a good, traditional style electrode plug that I can adjust the gap on.
Research shows that the NGK plugs seem to be favorite alternatives, but what would be the proper one for an early S?
Thanks,
Kevin G.,
'72 T Targa
Old 11-08-2002, 07:15 AM
Send a message via AIM to Oldporsche
Cool
I used champions (gasp! gasp!) in my 2.2E. They worked very well. (Just another Wal-Mart type of decision)
Good luck,
David Duffield
Old 11-08-2002, 07:30 AM
Friend of Warren
I used NGKBPR7ES in my 2.4E with MFI. When I was getting a lot of fouling I went with the hotter BPR6ES. That plug will support a gap up to .060. However I ran mine at .032.
Kurt V
Old 11-08-2002, 07:53 AM
I have a 9.7:1 compression ratio in my 2.7L and run BP7ES gapped at .045 (MSD, their high vibration coil, & 8.5mm Magnecore wires). The Webers are set to run rich.
I would think 7s or maybe 8s with the cleaner running MFI. At a buck & a bit a plug, a guy can afford to experiment.
JPIII
Early Boxster
Old 11-08-2002, 10:12 AM
Kevin,
I asked a similar question in which I listed plug recommendation from other threads. Go here to read the entire message.
Neil
'73 911S targa
Old 11-08-2002, 10:34 AM
Kevin G.'s Avatar
Muchas Gracias mi amigos!
Strange that the hot/cold numbers go in different directions between Bosch and NGK. Talk about confusing to know-nothings like me.
According to the chart provided by Neil K's link, the NGK BPR9ES is the closest match to my current W3DPO's. But based on the type of driving I do, (Stop & Go commute, and highway) I should be using a hotter plug such as the BPR8ES or 7ES as recommended by Mr. Stein, with the potential for the 6ES if I get fouling.
Looks like I will ride the fence and start with the 7's and go from there.
Time to Play!
Thanks!
Kevin G.,
'72 T Targa
Old 11-08-2002, 11:01 AM
Kevin, for what it's worth, I commute in my 72T in LA everyday. Started with Bosch (had always used them in Porsche and VW's) and at recommendation of Steve W and others on this board went with the BPR6ES. Car is much happier. My MFI system needs to be cleaned out and rebuilt, so it runs rich, as a point of reference - but I'm sold on NGK. In LA, I'd go hotter (no pun intended) rather than colder....
Scott
Old 11-08-2002, 01:59 PM
