<insert witty title here>
Christien's Avatar
radio wiring
A PO installed an aftermarket Clarion head unit. I want to replace it with another Sony head unit I took out of our old Honda before I sold it, but the wiring harness doesn't match. A quick google told me there are tons of these, and I have no idea where to start. I'm wondering if anyone might recognize these and be able to identify what kind of adaptor I need. Or am I better off just cutting and soldering? That's fine, if I have to, but I'd rather get an adaptor, if one is available. Here are the units:
old:
new:
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 06-02-2015, 01:01 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
old:
new:
What is the name or model # of the new unit?
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 06-02-2015, 01:54 PM
How is the clarion harness wired in? I just finished wiring a pioneer unit in. One of the POs had swapped the original Blaupunkt for one that you could pull in and out. All the original connections were cut. I had to connect loose wires to the harness. Not to bad since so few wires are actually used on these older cars.
Old 06-02-2015, 06:28 PM
Christien's Avatar
The new(ish) one is a Sony CDX-GT260MP: Sony eSupport - CDX-GT260MP - Support
The clarion looks like it was wired in a bit of a hack job. The power wasn't connected properly so that it disconnected whenever the car was off. A bit of a pain, as I can't save any presets, etc. That's one thing I'd like to correct. There's a whole mess of wires down there, including non-factory wiring to the rear speakers.
Old 06-02-2015, 06:38 PM
sony cdx-gt260mp harness | eBay
Try this.
1986 911 Targa.
Only in L.A.:
Old 06-02-2015, 09:11 PM
I don't see any adapters that convert a clarion harness to a sony. I think you will have to cut the old one out and wire in the new. Limited number of connections so it won't be hard and it sounds like the old one was wired incorrectly anyway since you don't hold presets (the constant and switched connections are likely reversed, which is what I did to mine).
I used crimp caps, which was much easier than soldering. The way it was wired I only had 7 wires to connect (constant, switched, ground, left +, left-, right + and right -)
Old 06-03-2015, 05:30 AM
