Tach goes crazy on my 82 sc
Hi all
My tach goes a little crazy. On idle It goes to 5000 rpm, 6000 then goes back to 1000 and julps again to high levels. Of course engine remains low rpm. It happens mostly when i start the car, after i drive it it goes away. Thanks for your help Last edited by The phoenix; 05-29-2015 at 11:34 PM.. |
Ive heard of a tach. What is a..
Its just a car. |
When the tach on my 88 started bouncing my oil gage would not hold steady either, in my case the alternator was starting to fail, hope this helps.
Check your voltage. An overcharging alternator will cause this.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Thanks. I'll check that
Eva
new voltage regulator fixed this issue for me
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
My 83 did this when the Paris Rhone alternator was failing....
Kroon Wire Harnesses
This problem can also be caused by a defect in your CDI box.
Kroon Wire Harnesses Specialized in Classic Porsche electrics www.kroonwireharnesses.com Check also our Facebookpage: https://www.facebook.com/kroon.wireharnesses |
Ok. I'll check the regulator first.
Thanks for helping |
Mine also did this when my alternator went bad.
It is a charging or DC storage issue.
As mentioned could be alt belt, alt itself, or when I had this problem, it was a ratty battery.
Mark TURBO = Free Power |
I had similar problem with floating/bouncing tach. It went away after I replaced the ground strap underneath the car. It was in bad shape.
great now i have something to fix. Mine goes crazy sometimes. I thought it was probrobly just a bad connection never thought it could be the vr
82 SC , 72 914 |
Skunk works
yep, my SC was the same
964 RS-4 |
I will know in a few days, at the moment the car is at the body shop for a little paint job
Check your grounds.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC '12 Gallardo LP-570-4 Performante Ducati 748R |
Well im pretty sure I found my problem. The red wire that goes from the ignition switch to the tach was completely fried. It was spliced before with a connector it must have fried after they did that theres no way they would have left it bare. but it doesnt go all the way to the switch it goes to a connector at the firewall where it goes into a bigger red wire. I cant repair it in that connector im wondering if i can just pull power from somewhere else or splice it to that wire on the other side of the connector. No worries my brother the electrical genious will figure it out
82 SC , 72 914 |
