Question wind noise
1987 carrera...driving at 3000 rpm on the highway and trying to enjoy the sound of my Monty muffler, is spoiled by wind noise/whistle...it seems that it is coming from the driver door, upper closure with the car body...but not really sure where exactly it is...
I am sure there are some Pelicans that experience this annoying problem on their Carreras...
I would appreciate some advice as to pin point the location of the leak and the remedy.
pictures really can help
thanks
Old 06-03-2015, 03:59 AM
Tape off the windshield with some painter's tape first, to make sure it isn't coming from a bad windshield seal, as is most common.
JR
Old 06-03-2015, 10:02 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Is it a Couple, Cab or Targa?
'85 Carrera Targa
PCA/POC
Old 06-03-2015, 10:04 AM
Wind noise
It is a coupe...
Old 06-03-2015, 10:17 AM
Formerly known as Syzygy
Canada Kev's Avatar
Do the same tape thing wih the doors as well. If the seal is old and flat, it can sometimes leak air. If neither of those prices to be the culprit, check the trunk. Lots of areas behind the dah that can leak if the front lid lets in air.
Kevin
Old 06-03-2015, 10:56 AM
DRACO A5OG's Avatar
+1 Tape the suspect areas and go from there.
Located the door seals to see if they are missing
'85 Carrera Targa
PCA/POC
Old 06-03-2015, 11:12 AM
ganun's Avatar
I replaced all the seals, strips and plugs but mine whistles right where david (OP) says also. Stuffing a couple of inches of napkin in the joint from the inside quiets it. I thought it was the mirror`s location on the drivers door. Pass side is OK.
I dunno whats up either
87 911 coupe, GP white, cashmere/black
64 Alfa Romeo Giulia TI - the violin
89 Peugeot 505 Turbowagon-other Pcar
67 912 coupe, white, sold
04 Audi Allroad 2.7T
Old 06-03-2015, 11:27 AM
DRACO A5OG's Avatar
When I replaced my door seal, I accidentally mis-aligned it and it created a whistle.
Lucky for you coupes you have this kit:
'85 Carrera Targa
PCA/POC
Old 06-03-2015, 11:40 AM
TheSt|G's Avatar
What am I looking at here?
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 06-03-2015, 11:48 AM
Parts that Porsche created to kill some of the wind noise in the earlier coupes, around the quarter window area. An '87 should have these.
JR
Old 06-03-2015, 11:58 AM
DRACO A5OG's Avatar
This is the kit that other site carries that start with A*********
'85 Carrera Targa
PCA/POC
Old 06-03-2015, 12:02 PM
Also available here...
Porsche 911 (1974-1989) - Bumpers, Doors, Latches & Lids - Page 3
Old 06-03-2015, 12:26 PM
wind noise
Thanks for the pictures...let me understand, i DO NOT HAVE A SEAL OVER THE DOOR ITSELF, ONLY A SEAL THAT SURROUNDS THE BODY CAVITY WHERE THE DOOR PRESSES AGAINST WHEN IT CLOSES...and..a FELT DEAL SURROUNDING THE BODY CAVITY AS WELL...AND STOPS 2 INCHES ABOVE THE DOOR UPPER HINGE.
Old 06-03-2015, 12:55 PM
Wind noise
Old 06-03-2015, 12:56 PM
Wind noise
Old 06-03-2015, 01:00 PM
Wind noise
Old 06-03-2015, 01:01 PM
Wind noise
PLEASE COMPARE TO YOUR SET UP ON A COUPE AND LET ME KNOW IF I AM MISSING A SEAL OR ANY SUGGESTION YOU MAY HAVE...
I did plug the plastic and rubber plugs
Old 06-03-2015, 01:05 PM
wind noise
where does this seal go? 911-531-095-03-M136
is it mounted on the door or the body?
Old 06-03-2015, 01:30 PM
It goes on the body. It's the one you have, shown in your picture.
Old 06-03-2015, 02:16 PM
wind noise
if it is mounted on the body then why the decryption of the part says that it goes on the door?
Old 06-03-2015, 04:10 PM
