3.2 - Throttle occasionally hesitates below 3k
Occasionally in my '85 3.2 the throttle pauses/dips while applying gas, only to pick up again a half second later. The issue only seems to happen below 3,000 rpm and only when the car is warmed up. May be unrelated, but she also just completely died when going around a slow 2nd gear bend, but fired right back up without complaint. The stall was also very smooth, as if one had just flicked a light switch.
The hesitations have me thinking the AFM wiper might need to be adjusted to a new track, but the random stalling out seems to be a complicating variable. Thoughts?
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
If memory serves me correct, you replaced the plugs and filters less than a year ago, correct? Mine has started to do the same thing, so I am leaning towards the fuel pump. Why else would there be that small delay? I also need to change my fuel filter.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
On the fuel side of things, swapped the filter last year and put in some Techron this spring.
Kind of Blue
I've had this issue since I bought my car. Changed the fuel filter, plugs, wires, and air filter and it improved. Replaced the alternator and the hesitation was even less noticeable but it still persists just a bit and only below 3000 RPMs. I wonder if it's a vacuum leak somewhere.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
It's not so much a hesitation as during a consistant throttle application, the power cuts, and then kicks back on again a half second later. I think Chris is on to something with the fuel pump, as I now remember hearing it buzz fairly loudly the other day.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs Last edited by TheSt|G; 06-08-2015 at 10:52 AM.. |
I also have an 85, I just went thru the same issues as you. The fuel pump was going up and then did, I put a new pump from our host and runs so much smoother in lower rpms. I would start with the fuel pump, Plus its a good piece of mind knowing it is new. I went up and had to have it towed home.
If it was loud the other day it is the pump for sure, Mine did the same thing. The wife asked why there was a loud noise in the front, I told her fuel pump going up two days later it did. Not hard at all to do Good luck |
I had a similar issue with very slight bucking at little load around 2500-3000 RPMs. I did two things that seemed to fix the issue. I removed my AFM, cleaned the track and contacts and lowered the contact arm so it ran on a new track. While the right side of the air box was removed, I checked most of the 12 intake bolts. Two were very loose. There was at least one I simply couldn't get to.
1986 Carrera coupe - black on black 1972 CB500/4 |
Member 911 Anonymous
Take care on the OEM PAG pump, make sure it does not buzz out of the box. Take note of the 2 year warranty.
Mine started to buzz after a year, thinking no way it is bad since it is OEM. waited to long and tried to replace but warranty ran out.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Kind of Blue
Order a new rubber hose. The one from the tank to the inlet side also. Very easy job but you will get some gas down your arm....
Welcome to stop in when my parts get here. Quote:
*Edit* Found it on Pelican, added to order. Thanks for the heads up.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs Last edited by TheSt|G; 06-08-2015 at 11:49 AM.. |
I called pelican and asked them .told them what pump I was getting and they new. .I think it was 12mm rubber fuel line...
Yup, just found it in the catalog and sent them a memo to add it to the order with another hose clamp.
Gunga Galunga
I had the throttle cut in/out at WOT. I found this while T/S'ing:
1984 Carrera bucks and pops when cruising at medium throttle. Was not the problem. It turns plugs/wires/cap/rotor/and fuel filter ended up resolving the issue. There is a procedure for testing the Throttle position sensor, can't remember whether it was in Bentley or on the forum though... |
