AC help
My evaporator died so I replaced it with a new one which was pretty straight forward. Except the 3 1/8" hose going from the evaporation housing to the ac ducting fell apart. Where can I buy this hose? I have 3 different kinds of 3" brake duct and air duct hose that cannot be stretched over the 3 1/8" housing.
one source would be:
Pilot Supplies and Aircraft Parts from Aircraft Spruce in SoCal Here is their page for flexible tubing: http://www.aircraftspruce.com/search/search.php?s=SCEET&x=0&y=0 pick the type you want and they have all kinds of sizes that vary by t.he 1/4" Last edited by SpyderMike; 08-12-2017 at 03:59 PM.. |
Excellent, thank you very much!
One thing you might consider, depending on the tubing type that you select, is cutting the support wire back a ways (say about an inch), and folding the tubing back inside itself to double it up. That is what I did for SCAT tubing to strengthen the area where the band would be.
Mike |
Kuel provides the ducting piece in one of his kits, maybe he will sell you one.
Sold: 1989 3.2 coupe, 112k miles |
I bought mine from Pelican
Lorne M.
83 SC |
Member 911 Anonymous
Go to Home Depot, get the dryer 3" hose, tight fit but it works, just cut to size.
But it will fail concours, +2 purchase OEM part from Pelicans
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
