So to get to odometer to work accurately you would need the gears to me changed as above. If you were to just change the speedo dial/faceplate from the MPH/KMH faceplate to the KMH one would it still read OK as the needle will still be in the same place throughout its range?
I looked into doing what you want to and the answers I got were not very assuring and confusing. I ended up sending the speedo to North Hollywood. Took about 4 weeks and had the speedo overhauled and converted. They also reset the odo to read the same mileage but in Km. The indicator is a weird color because of the light, they repainted it the correct red and the speedo looks great.
1988 Carrera coupe 1966 250 Ducati 2015 VW Golf TDI gone because Dieselgate! 2021 VW Golf TSI 2014 Ninja 300 |
I'd have to factor in the shipping cost from and to Australia Thanks, Frank |
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
I think I have a set of the conversion gears. If so, I can convert a working MPH speedo to Km including a new face, new gears, reset odometer, and restore needle and bezels for about $350.
BTW do you still do the AFR in the bottom of a Tacho? Cheers, Frank
76 911S Land Rover 110 Defender |
