-   -   need imaginative ideas to split calipers (http://forums.pelicanparts.com/porsche-911-technical-forum/87030-need-imaginative-ideas-split-calipers.html)
smithH 11-27-2002 04:38 AM
Dickster,
mines garage is like that , I cant even drive the car in, too narrow to open the doors. Consequence of living in S. England I guess. Still pleased to hear you get your car in. When I have to put mine away, I end up pushing it in!!!
PS - you should paint the walls, it makes load of difference to the light levels, a tin of white emulsion is only 10quid.
cheers
h
dickster 11-27-2002 04:47 AM
h,
christ, mines large in comparison!
i thought about the white, but i've got two 5 foot flourecents in there - may need to change to doubles. the walls are made from 'orrible breeze blocks that take a 'ell of a lot of painting (tiny holes).
smithH 11-27-2002 04:49 AM
yes, mine is breeze blocks too, didnt take too long with a roller. Slap it on thick, its not like its your living room (although I do spend more time in it!!!)
H
jmohn 11-27-2002 05:52 AM
Two questions. First. Why do you have to split the caliper to rebuild it? I thought you could pop out the pistons, clean the bores, re-seal without splitting them. Second. What are "breeze blocks", I have a construction background (here in the USA) and I'm just curious.
Jerry M
'78 SC
dickster 11-27-2002 06:08 AM
jerry
the calipers are easier to work on thats all.
breeze blocks are larger than bricks as seen in pics (not sure of std size as i haven't worked in construction for over 10 years),
usually used where the cosmetics doesn't matter or they get covered.
they're made from like a concrete and light aggregate (small stones etc) mix. sort of like a concrete driveway.
for non load bearing walls you can use softer ones, load bearing (two in my garage) are much denser (?) concrete and are a real PITA to drill.
well, thats my uneducated explaination!!
911pcars 11-27-2002 10:18 AM
If you must split the calipers, how about bolting them up to the strut to hold em while you unbolt them?
Sherwood Lee
http://members.rennlist.org/911pcars
revision:
Oops. I just saw your requirement no. 3. Never mind.
dickster 12-04-2002 11:49 AM
yes, the vice method did the trick. thanks to all advice.
dickster 12-04-2002 09:39 PM
heres a couple of pics
http://forums.pelicanparts.com/uploads/calipera.jpg
http://forums.pelicanparts.com/uploads/caliperb.jpg
Emission 12-04-2002 11:21 PM
I just re-built my 930 calipers and bought a full set of gaskets and scrapers. I didn't need six of the scrapers, so I didn't use them. New, they were about $25 each from the dealer. I'll sell them to you (unused in Porsche wrappers) at a great price...
Part # 930 351 547 00
E-mail me if you are interested.
BTW, I never broke mine apart. Just cleaned the really well, new seals and a couple new scrapers... Perfect now!
