What goes here? Bracket on left side of 911SC motor
Changed my fuel filter today and noticed this bracket (circled in red) with nothing attached to it. Thoughts please.
TIA ![]()
Wayne 1980 911 SC 1960 MGA 1600 |
Fuel line loop clamp is missing.
Thanks! Do you have a picture of that loop clamp? Do u know part number?
Did some looking in the PET... Could not find fuel line loop and/or loop clamp. Alternatively, could this be a support ERG valve setup. Did 80SC have ERG? Was it on left of motor?
On my 1980 SC ROW, there were two lines thru that clamp. Both were about 8mm max, one fuel and one vacuum. I believe they were lines going to the warm up regulator between the #1 and #2 runners. Don't know the size of the clamp, but it was a rubber-lined clamp that had been squashed a little oblong to handle the two lined running thru it. Maybe 5/8"/15mm?
Thanks cmonref - I would appreciate a photo if you can. TIA
Sorry. I removed the CIS two years ago in favor of MS EFI. The unit is sitting on the back of the shelf, up high, with that end against the wall.
More Likeable IRL
hey mr walker, thanks for continuing to contribute here. I can count "contributors" on one hand now days. im not counting myself, while counting you sir twice.
thank you.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Thanks for followup cmonref.
Anyone - Looking for photo of driver's side of motor showing clamp and hoses. TIA
Lost in the 1660s
I think this is what you want to see:
1978 911 SC Targa |
Thanks drmac! Hate to ask for more... Could you id where each hose goes to on both ends and maybe a wider shot?
TIA
Lost in the 1660s
I have not got a better pic on hand, but on my car the clamp John Walker identified as missing on yours holds the cylinder 2 and 3 fuel injection lines, so the lines each run from the fuel distributor behind the airbox to the injectors on those driver's side cylinders, 2 and 3. Others may correct me, and this advice is novice advice. Hope it helps.
1978 911 SC Targa |
Thanks drmac, that info helps a lot!
Have a nice weekend. Wayne
Yes, thanks for the photo! I think I may actually have several of those clamps lying around...
I pulled some of the heater hoses out again and found the clamp (or another one) with number cyl 2 and WUR clamped below the heater hoses. So, I see that cyl 2 was routed in the wrong place.
Now I need to figure out how the WUR fuel hose is routed. I think I may need one or more of those clamps - anyone have any ideas re the part number? And or source. Thanks again for all your help! Wayne
