brake lite switch
1981 911sc
I have to push the brake pedal pretty far to make the brake lights go on. The Switch is on the master cylinder. Is it ajustable? Can I take it out and repair or need to replace it? If I need to take it out, are there brake fluid issues?
Tx1john
Old 11-17-2002, 01:36 PM
JDaniel's Avatar
Switches are not repairable. They're easy to replace, and not that expensive.
If done right (push brake pedal down and hold w/2X4) you don't have to bleed brakes, but I would, just to be on the safe side. There may be a tiny amount of fluid dribble. Keep a rag nearby and don't get brake fluid on anything painted.
Check through the archives there is a mass of posts about this very question.
Dan Tolley
1987 911 Coupe
The Owner's Gallery
2006 Audi A4 3.0q Cabriolet
2003 Ford F-150 XL Lumber and Trash Hauler.
Old 11-17-2002, 02:27 PM
Driving member
jester911's Avatar
There are two seperate switches on the m/c on my 86. Not sure if it is the same on yours but I assume it is. Just replace both. There is no repair of these as far as I know. Make sure to look at the switch to see if it is 2 or 3 prong. Some years had both. You can see the prongs on the side of the m/c.
You can buy them here.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 11-17-2002, 02:30 PM
