Parking light fuse problem
I'm the new owner of an '86 Carrera. The fuse for the left side (driver's side) front and rear parking lights keeps burning out [Fuse box 2, Fuse position #5]. I went through a hand full of the correct type fuses and one of them did hold but a small amount of smoke started coming out the driver's side dash and driver's side headlight so the lights were shut off ASAP. Any help?
http://forums.pelicanparts.com/uploa...1434425696.jpg http://forums.pelicanparts.com/uploa...1434425713.jpg ^^^^^ The above pics are of the '86 M/Y fuse panel. Your attempted troubleshooting procedure may have created a serious issue. I would strongly suggest an end to your fault isolation protocol. pm me as needed. Good luck, Gerry |
Much thanks for the diagram. Learned where the wire penetrates the body so I'll wire chase to see where it cooked.
| All times are GMT -8. The time now is 10:58 PM. |
