I suspected it may be wrong, thanks for verifying it. |
I guess the question remains, what could I have unhooked in the engine compartment that would effect tach signal? Anything? It' seems odd that my tach stopped working when it worked when I pulled it in the shop 3 weeks ago to drop the engine.
Did you do a continuity check from DME connector pin 21 to the back of the the tach?
The tach connects on a flat 4 wire connector.in the trunk above the gas tank , Doesn't necessarily have 4 wires. 2 small black wires, 1 black, purple stripe tach drive wire and a yellow wire.
There is nothing to drive the tach in the engine compartment of a Carreras. Bruce |
UPDATE:
No continuity between Pin 21 black/purple wire at tach Pin 11 has continuity to what appears to be a black wire next to the black purple in the 6 pin that goes to the back of the tach. |
It would seem there would have to be a wire from the coil or the injectors telling the DME what rate they are firing at. |
So you got continuity between pin 11 & the BLK on the back of tack which is good.
Since you got no continuity between pin 21 & the BLK/VIO (purple), you will need to trace that wire. If you can find the connector that Flat6pac mentioned, re-do the continuity check from that connector to the back of the tach one way and to pin 21 the other way. |
The high voltage pulses (several hundred volts) that are fed to and drive the coil are developed INSIDE the DME using speed sensor/index sensor etc. The tach pulses are derived from that circuit and sent from the DME directly to the tach. Obviously, if the car runs, the speed and index sensor work AOK. Older cars with conventional ignition use the points or an output from the CDI unit to drive the tach. |
The black wire on the 4 wire connector I mentioned, there is 2. One runs to the up shift light and the other runs to the fuel pump relay under the seat. I think the yellow wire shuts down the A/C under hard acceleration.
Bruce |
I tested this harness to the DME and got continuity on the larger black/violet wire but not from the smaller to the tach. It would seem I have a bad wire. So should I run a small from the larger black/violet up to the terminal and the tach and test?
http://forums.pelicanparts.com/uploa...1434810018.jpg |
Oh good grief, now it shows continuity when I plug the connector in. I'm going to fire and test.
Aaaaaaaaaaaaaand we have tach again. How flaky. |
Good. its 12:00 somewhere in the world so have one or two...
http://forums.pelicanparts.com/uploa...1434813766.jpg |
We've all learned some things today..
Bruce |
http://forums.pelicanparts.com/uploa...1434830001.jpg |
| All times are GMT -8. The time now is 11:03 PM. |
