Tach not working after engine drop an install
I got my engine back in my car and got it fired after replacing head studs but my tach isn't working and it worked before I dropped the engine. I had to miss a wire somewhere. The connector in the tunnel had a broken wire that I repaired. I'm going to go back through my intake runner grounds and make sure all are making contact and I already checked the ground strap from the transmission to chassis.
Any suggestions? |
first suggestion is to state the year.....of the car
Sorry, it's an 85. Not sure how much difference that makes when it comes to the tach other than my tach wiring works differently than the early year cars. I guess I figured the 3.2L was a giveaway for 85 or newer. Didn't consider transplants but figured transplants would be using motoronic.
DME plug, 14 pin plug solidly connected?
Have to recheck my connection to the DME. I might not have it squarely connected. I'll let you know if a few minutes.
Thanks for the suggestions. Just checked, connectors are all tight. Noticed when I fired it to check, when I shut the car down the tach jumped a little. Don't know if that helps or not. |
No joy. I unplugged the Main harness and plugged back in. I also cleaned all the grounds back at the intake runner. Tach still jumping when I shut the engine off. It seems like I have to be missing something obvious since it worked 3 weeks ago when the engine came out for the head stud replacement.
I'm going to check the connection on my speed sensor. If it checks good, I'm going to verify the correct gap again. I think the speed sensor is what tells the ECM how fast the engine is turning.
Cabmando
Really interested in this because my '76 2.7L is doing EXACTLY same thing. Tach worked before engine drop, no work after engine install, Tach needle jumps a slight bit when I turn the engine off.....I've hear ground strap betweem tranny and body, I just havent gotten under there. My strap is really frayed. |
The tach pulses are sent from the DME on DME connector pins #4 and #11. #4 blk/violet wire, #11 blk wire. These wires run direct to the rear off the tach. Pull the DME connecter loose and check their continuity with a multimeter to the rear of the tach. |
FWIW I got under the car and checked the ground strap at from the trans to chassis and all was good. I cleaned it and reconnected. Still no tach. |
Pin 11 blk wire is the fuel injector pulse widths for the CASIS light. |
http://forums.pelicanparts.com/uploa...1205355264.jpg |
Above post ^^^^^^^ is why the Bentley manual scares me; it suggests pin 11 and pin 21 are identical. That is far from true. More likely the authors didn't know which pin does what.
Rick has it right. Pin 21 puts out a pulse for each spark event. This is used by the tachometer to display RPM. Pin 11 carries the fuel pulse length. The duty cycle of the signal is evaluated in the tachometer to decide when to turn on the shift light. Further, if you mix these wire up when connecting the tachometer you will inevitably destroy your DME. First the car will run lousy and next it will quit altogether with no fuel. The reason for this is that the signal on pin 11 comes directly from the fuel driver. And when you hook that wire up to the tachometer input the pull-up resistor of the tachometer will drive current into the DME and destroy the fuel driver. This is an expensive repair. Ingo |
I was looking at ACTUAL wiring diagrams in the Bentley, 970-30 '88-'89 DME does use pins 4 and 11 for the tach. I just looked at it and assumed all years of DME were the same.(my bad to assume) Pg 970-26 shows the '84-'85 Carrera diagram, and indeed it uses pins #21 and # 11 to the tach. As the OP has an '85, pins 21 and 11 it is. Obviously the '84-'87 DMEs are different than the '88-'89, at least for the tach signal. Didn't know that, or is the Bentley possibly in error? |
All NA 84 - 89 use the exact same pin-out for the DME. Pin 11 for shift light and pin 21 for RPM. Pin 4 is the starter (to turn on the fuel pump via the DME relay).
The turbo is completely different, it doesn't use a DME. Ingo |
wire #11 can be disconnected if you don't require the upshift light (anybody really need it?) |
| All times are GMT -8. The time now is 11:58 PM. |
