-   -   AC compressor doesn't activate every time I turn the fan switch on (http://forums.pelicanparts.com/porsche-911-technical-forum/871224-ac-compressor-doesnt-activate-every-time-i-turn-fan-switch.html)
afalcfan 06-18-2015 09:09 AM
Does the ac compressor have a shut off if the system is low on freon? The car is a 1984 Porsche 911 Carrera
GH85Carrera 06-18-2015 10:11 AM
If it is 100% stock, no it does not. It should have one but it does not as delivered. If you ever have a chance add one.
RSTarga 06-18-2015 10:22 AM
Is your switch good? The contacts tend to weaken from the heat.
86 911 Targa 06-18-2015 10:24 AM
Green wire.
Have a look at the green wire on your compressor.
It has a tendency to get loose, or corroded.
Good luck,
Gerry
pm me as needed.
rusnak 06-18-2015 10:48 AM
yup, check for 12 volts at the compressor. You could have a stuck AC relay or a bad switch.
kuehl 06-19-2015 09:37 AM
afalcfan,
The system is simple.
1) Evap motor Fan Speed Switch on Right turns on the ac system in a 'ready state'.
2) Thermostat Switch on the Left changes the state.
Fully CCW (to the left) is off, or warm,
Fully CW (to right) is max cold.
The thermostat has a sensor (a metal tube filled with refrigerant gas; the tube is between a bellow in the thermostat and its end is crimped; hence a sealed unit).
The sensor goes inside the evaporator. When the evaporator is warm and the thermostat is set to a particular degree of 'cold' then power flows through the
thermostat to the compressor. As the evaporator gets too cold at that set point it turns off the compressor. The refrigerant gas inside the sensor tube expands
and contracts and tuns on and off the compressor.
Read: The AC Temperature Switch - An example in detail with a typical 911 Porsche
here: troubleshoot-the-ac-system/
TargaRich 06-24-2015 04:17 PM
Had the same issue a few months ago. Inexpensive relay in smugglers box from Advance Auto Parts solved the problem.
kuehl 06-25-2015 04:47 AM
http://forums.pelicanparts.com/uploa...1435236450.jpg
jlex 06-25-2015 06:33 AM
X2. The relay is on its way out...
WyattEarp 06-25-2015 06:56 AM
I had same thing happen to me. Sometimes I got nothing and sometimes worked fine. New relay in smugglers box fixed it.
realgren 06-25-2015 08:09 AM
As stupid as it sounds, check the fuse. That was my issue.
86 911 Targa 06-25-2015 08:33 AM
Relay replacement.
http://forums.pelicanparts.com/uploa...1435249908.jpg
Replace with this.
http://forums.pelicanparts.com/uploa...1435249966.jpg
And add this!!!!!!!!!!!!!!!!!!
Good luck,
Gerry
86 911 Targa 06-25-2015 08:39 AM
Re-routing Fuse #2 electrical.
http://forums.pelicanparts.com/uploa...1435250056.jpg
http://forums.pelicanparts.com/uploa...1435250079.jpg
http://forums.pelicanparts.com/uploa...1435250105.jpg
http://forums.pelicanparts.com/uploa...1435250127.jpg
This mod reduces the current burden on fuse #2
which has a tendency to overheat & corrode.
http://forums.pelicanparts.com/uploa...1435250322.jpg
Here's a pic.
Good luck,
Gerry
afalcfan 07-04-2015 09:49 AM
Thanks for the all the help. It ended up being the relay that some of you advised.
