What lights should be on?
On a USA car - engine off - lights off - left or right turn turn signal on E.G. Turn signal lever down or up.
I expected left marker or right marker lights on respectively - my car has both sides on.
TIA
Wayne
1980 911 SC
1960 MGA 1600
Old 06-10-2015, 04:25 PM
Should be left or right, not both. Any issue when ignition in on, or car is running? What about emergency flashers?
Old 06-10-2015, 04:42 PM
Thanks. All other light function work as expected. I guess I have some troubleshooting ahead of me.
Wayne
1980 911 SC
1960 MGA 1600
Old 06-10-2015, 04:46 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Diode.
Not sure if your M/Y has a diode under the dash.
If so check it.
If this is the issue, just buy diode @ your local electronic shop
and solder it to the small pc board.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 06-10-2015, 05:17 PM
Hi Gary,
Thanks for this info! Where, under the dash, should this diode be located?
Wayne
Wayne
1980 911 SC
1960 MGA 1600
Old 06-11-2015, 06:09 AM
Diode.
Hi Gary,
Wayne
Between the steering wheel, and the light switch. (If you have one).
Gerry
1986 911 Targa.
Only in L.A.:
Old 06-11-2015, 06:20 AM
Thx.
Wayne
1980 911 SC
1960 MGA 1600
Old 06-11-2015, 06:32 AM
OK, I resolved the light issue - it turned out that an old aftermarket alarm harness that I finally removed caused the issue. Remove harness - left and right lights work independently again. This removal seems to have caused a new problem - plus, there is no diode to be found - it looks like there may have been one but it was removed and the two wires hooked together (maybe).
New problem:
Before the removal of this harness, I did not have a buzzer associated with keys in the ignition, car off and door open... I have have a buzzer - but there is a problem.
1) OK - Car off, buzzer on, remove key - buzzer off.
2) Not so OK - Key in, door closed, start car buzzer on... I have to open the door and close the door (car still running) to get the buzzer to go off. Arghhhhh!
3) Not so OK (just found this) - Door closed, turn key to ignition (not acc), buzzer on... turn key off without starting motor, buzzer off.
Geeze, I hate previous owners and their mechanics.
Wayne
1980 911 SC
1960 MGA 1600
Old 06-22-2015, 11:04 AM
Hmmmm - buzzer may actually be working as designed. Did some more research and it would seem that the key buzzer is also a seatbelt buzzer (?) - if so, all seems to be working as designed.
Now I just need to sort out the missing diode.
Wayne
1980 911 SC
1960 MGA 1600
Old 06-22-2015, 11:37 AM
I have no buzzer... nor is my parking light working. Maybe I should just leave it be :-)
Old 06-22-2015, 11:44 AM
