Need advice with this situation
Car was hit high in right fender and it flattened the oil hose, how could I go about repairing? Are these parts still available or will I have to take another route.
Tru6 Restoration & Design |
Fleabit peanut monkey
Pull the line. Figure out how to pressurize with air and using a propane torch to soften it will pop back into shape. Don't know the ins and outs but it has been done.
1981 911SC Targa |
1981 911SC Targa |
Brilliant!! Now I just have to figure out how to loosen those nuts up,looks pretty tight up where the thermostat is. Does someone have another brilliant idea or thread to share.
Pm me for free "pipe plugs" for the pressurizing with heat solution -- "easy peezy"
Brew Master
Be careful with the heat and how much air you use. If the line is creased at all you can split the crease if you apply too much air while heating. I fixed a line on my car that was crushed at least that bad. Another note, use Kroil or PB blaster for a few days before you attack the fittings on the thermostat.
Started the ritual PB blasting for PIA nuts. This appears to be a 5 to 10 curse word job, I know those nuts are gonna put up a good fight.Thanks for the help guys
Brew Master
Go easy on those nuts. If you feel much resistance coming off stop. My brother stripped his and had to install the thread savers on his.
That's what she said.
That's what he said.
French Import
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Once you get the concave part outward and slightly proud of flat, just squeeze them round with channel-locks. Too much heat and they pop, so go slow.
Best way to round out the tubing is with a crescent wrench. Adjust the wrench where the round part is and start working towards the flat part rotating the wrench as you go. You may want to heat it but you need to be careful.
If you have never tried this take a piece of tubing and flatten part of it then take the wrench, adjust it to the pipe size and work it towards the flat part rotating it around the pipe as you go. It works. Other then that, you can heat the tubing - I think they are steel until it is cherry red and do the same with the wrench. It does work.
SteveKJR Proud Owner of a 78 911 SC Targa "A Porsche does more then just go fast in a straight line" |
Both of mine were crushed totally flat by the P.O. I just replaced them. Had no idea how lucky I was to get them off with no damage to the thermostat. You may consider using anti-seize on the threads for assembly.
Removing oil lines....
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Banned
Thanks for the input,Shaun your a funny man.
Ok tried to loosen nuts no go wouldn't budge,tried heat PB blaster et. Does anyone have any more input before I take all the lines and thermostat out??
Been There Done That......
Much easier to deal with on the ground! Let me know if you want to borrow the super wrench!
5$ of copper piping works just fine, if its not in a high vibration area...
