Bob Harriman's Avatar
Paint lug nuts?
Can my natural color alloy lug nuts be painted black without everything just scratching off easily. I know it depends on how they are removed and put back on but is it worth it or a waste of time?
Bob
Old 10-22-2013, 08:18 PM
S2GART's Avatar
Sure they can be painted. I have freshened up my lug nuts simply by spraying them with semi-gloss black. Be sure to let them dry real well before putting them back on. Any scratches can be touched up by hand.
The "collection"
1983 911 SC Targa (1 of 1430 imported)
1994 MB E320 Coupe (1 of 825 imported)
1992 MB 190E 2.6
2004 Volvo V70 2.5 Turbo (1 of a bazillion imported)
Old 10-22-2013, 08:45 PM
RETIRED
Joe Bob's Avatar
I use Trim Black by SEM.
2012 ML350 3.0 Turbo Diesel
Old 10-22-2013, 08:47 PM
AutoBahned
RWebb's Avatar
sure; but the black paint will just scratch off easily when you R&R them
I've been thinking of going from black to silver for just that reason...
Old 10-22-2013, 09:18 PM
Rescuer of old cars
Arne2's Avatar
Yes, you can paint them; yes, they will get scratched up shortly; yes, you can paint them again.
Tip - if you do paint them, don't get paint on the ball seat area where they contact the wheel. Paint can get soft if the wheels get hot, leading to loose lug nuts, which is never a good thing.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 10-22-2013, 09:23 PM
joefrantz's Avatar
I've tried painting with both Wurth and SEM satin black. They look ok for a while, but eventually they chip along the sharp edges.
A soft socket helps, but not much.
You can also use a thin layer of plastic (like a grocery bag),between the socket and nut, to provide some protection. Still gonna chip, but it does help a bit.
My latest ploy is painting with krylon fusion paint for plastic. A very thin coat, no primer. Best durability so far. Starting to see bare edges after about 6-8 removal/install cycles.
The best thing is you can strip and repaint them in about an hour.
Joe Frantz
73 911 T
Old 10-22-2013, 10:09 PM
cnielsen's Avatar
Batch anodizing is cheap. My local shop said they could do a small bucket full of lug nuts for $100 or so. I'm going to machine the ends off a bunch of mine for longer studs and have them anodized. I will report back with the results
'67 911S
'69 911S,
'70 911ST
'73 911T Targa Signal Yellow
'78 911SC backdate
Old 10-22-2013, 10:31 PM
Will powder coating work as good or better than anodizing?
Bob
Old 10-22-2013, 10:51 PM
cnielsen's Avatar
No, don't powder coat them
Old 10-22-2013, 11:13 PM
Vintage Motorsport
RichardNew's Avatar
I painted mine with rattle can paint. I then use a black Magic Marker to touch them up.
Richard Newton
Car Tech Stuff
Old 10-23-2013, 03:49 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Put some Saran wrap on them before putting the socket on them.
Who Will Live... Will See
Old 10-23-2013, 04:20 AM
Undocumented User
McLaren-TAG's Avatar
Or make your car look like it's got hair on its chest and get it some steel lug nuts.
Old 10-23-2013, 05:25 AM
Forget painting the lug nuts and just drive the piss out of your car.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 10-23-2013, 07:26 AM
Craig T's Avatar
+1 Go steel. I have a whole box of allow lug nuts that need painting if anybody wants them.
Semi-gloss painted lug nuts??? We don't need no stinking glossy lug nuts.
Craig T
Old 10-23-2013, 07:36 AM
got some open ended
Bob
Old 10-23-2013, 09:17 AM
RETIRED
Joe Bob's Avatar
Eliminate the problem, polish them with rag wheel and rouge on a bench grinder.
Old 10-23-2013, 09:33 AM
Porsche Enthusiast
rsnodgrass's Avatar
How did re-anodizing the lug nuts black go?
74 Carrera 2.7 | 75 Turbo 3.0 | 97 Boxster | 12 Cayenne S
GONE >> 04 GT3 | 75 Carrera 2.7 MFI | 76 Carrera 2.7 MFI | 77 Turbo Carrera 3.0 | 86 Carrera 3.2
Old 11-01-2013, 06:53 PM
Does anyone make a black plastic cap that will work?
On my 924.......a black cap over the lug nut was standard
Old 11-02-2013, 04:40 AM
Mo money = mo parts
+1 If you do choose to paint, the challenge is keeping paint on them. I actually use a plastic grocery store bag. Double it up and slide the socket over it. The bag gets destroyed and you need to keep moving it around, but it will HELP preserve the paint. Eventually, the paint will come off, and they will need repainted, but your paint will last a lot longer.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 11-02-2013, 04:56 AM
Norm Faustino's Avatar
Plasti dip can be thinned with naphta and sprayed with even the crappiest testor's airbrush in between cycles and looks awesome. You can also use the aerosol can but you wont have as much control where it goes.(more masking)
78 911 SC "Scratchy"
2004 Mini Cooper S "Pele" (gone but not forgotten)
1979 classic mini clubman-"Coolio"
Old 11-02-2013, 07:10 AM
