-   -   What does this rust suggest? (http://forums.pelicanparts.com/porsche-911-technical-forum/872294-what-does-rust-suggest.html)
Otter74 06-26-2015 01:46 PM
The attached photos are of the right front fender and battery tray area of a car that I saw that was of enough interest for me to talk to the owner about. In almost all respects it is a car that hits all my important points (excellent mechanically, cosmetically good enough) but these two rust areas are of some concern. I am not sure how much concern they should be, so I thought I'd ask people who know better.
The car is an SC coupe, and otherwise has a perfect body - never hit, original paint everywhere, floors perfect, etc. the owner described these areas to me and took the photos to send me.
The rust on the fender is presumably where it adjoins the firewall/cowl panel. My question is this: can this be addressed by simply replacing the fender (seller has a spare) or is metalwork likely to also be needed on the cowl panel? The former is basically OK with me, the latter probably not.
The other photos are of the battery box area - it looks like the inner fender/body panel that is on the left side of the battery. This is of possibly greater concern to me, as it looks like it has gone completely through that section of sheet metal, but perhaps I am not looking at it right.
http://forums.pelicanparts.com/uploa...1435351533.jpg
http://forums.pelicanparts.com/uploa...1435351558.jpg
http://forums.pelicanparts.com/uploa...1435351585.jpg
http://forums.pelicanparts.com/uploa...1435351603.jpg
jpnovak 06-26-2015 01:52 PM
The front trunk rust is due to crap buildup on the exterior surface of the front bumper mount trapping moisture and the rust perforated the inner fender well. Yes, invasive surgery.
The fender could have migrated to the vertical fender support. pull the front wheel and have a look with a good bright light.
mreid 06-26-2015 01:59 PM
That line of rust bubbles is where the inner fender vertical attaches to the fender. I'd say the best course of action is to replace the fender and perform major surgery on the fender mount. With that, it's almost a sure bet there are other rust areas you don't know about...yet.
DanielDudley 06-26-2015 02:09 PM
Look at the back wheel wells up and into the back of the door area. Look at the bottom of the door openings as well
KTL 06-26-2015 02:20 PM
Yep I agree with Jamie. The bracketry which holds the bumper shock absorbers collects a ton of debris- rocks, sand, bits of asphalt, etc. That pile of crud absorbs water and just sits there- a perfect site to foster rust.
If the car had been in crash, those brackets can get damaged and would warrant replacement. If the area where the brackets are fixed/welded to the body is not properly prepped, it would invite major rust like this.
Also keep in mind that a leaky battery can cause rust to start there. That Interstate battery has a vent port right near that awful rust
Agreed with Jamie that this requires invasive surgery. We're talking cut out a section of the chassis tub and replace with donor parts or new parts. Serious work. And when you can see rust on the exterior, 9 times out of 10 there's more to be found where you can't see it. I'd be sure to look at this car with a very suspicious eye.
Biff 06-26-2015 02:52 PM
Tip of the iceberg! SmileWavy
74-911 06-26-2015 02:55 PM
That can't be rust, that is a galvanized body....
Not trying to be a smart a$$ but the number of postings re: don't buy a middie as they rust is BS, i.e. case in point, they all will rust. And as several pointed out, that may be the tip of the iceberg so tread carefully.
LEAKYSEALS951 06-26-2015 03:01 PM
First comes love... Then comes marriage...
http://forums.pelicanparts.com/uploa...1435356028.jpg
jdbunda 06-26-2015 04:02 PM
Rust at that battery spot due to collecting debris at the bumper bracket suggests there will also be some at the corresponding place in front of the rear wheels - check inside the doors right at the rear edge of the rubber sill cover. I would bet you an alloy lug nut that you could push a screwdriver through the door sill.
mreid 06-26-2015 04:05 PM
Post a picture of the door jams, sills, and lower areas around the windshield and rear windows.
LEAKYSEALS951 06-26-2015 04:24 PM
No- wait a minute-disregard my first post- this one is better:
http://forums.pelicanparts.com/uploa...1435361031.jpg
Joe Bob 06-26-2015 04:47 PM
Typical rust....started with the 356 and continued.
Dpmulvan 06-26-2015 04:54 PM
Run from the car as fast as you can unless he's practically giving it away
Joe Bob 06-26-2015 05:37 PM
SCs had rust galivination......so, something is wrong. Heavy salt state?
If so, heavy discount, but replacement panels ARE available. Depends on your level of commitment.
Bill Douglas 06-26-2015 06:17 PM
I tend to assume if there is rust somewhere (especially that badly) there is rust in other places as well. They are also prone to rust around the sills where road salt and stuff gets flung up and forward by the back wheels then holds moisture in. This is a place you can't see and is a PITA to fix when the car is torn down for repairs.
But good luck. Not trying to be negative, but just hoping to help you avoid costly, unforseen things that come along with these cars - did I mention headstuds.
Tippy 06-26-2015 06:25 PM
Project McDonald's? ;) :)
Reiver 06-26-2015 07:27 PM
Unless you are a great body guy (cutting, fashioning panels, welding) you will be into deep pockets territory right quick.
For a long hood, at prices today, you can do well.
Prices on SC's are moving upward but not at the level yet where you could part that work out and be good.
Charles Freeborn 06-26-2015 09:12 PM
To answer your original question, it probably means there's more rust....hope you know how to weld..
-C
sugarwood 06-26-2015 10:34 PM
Seller has a spare fender, but didn't bother to replace it?
That always makes me pause. Like he figured out it was more complicated than that.
Otter74 06-26-2015 11:02 PM
Seller said he has a spare fender but since it's in a different color, it would have to be painted to match, and since the rest of the paint is sort of weathered that would mean reprinting the whole car, and then you start driving it less, etc. i could see myself making the same decision.
Regardless, while I will ask for some picture on some of the above mentioned areas, I am probably going to pass on the car because of that. My Fiat has rust, and I don't want to deal with any more rusty cars....
