SC Engine wiring harness connector
I need some advice on how the main engine wiring harness connector is dis-connected at the electrical box on the bodywork at the left side of the engine? Is there a tab or other locking device that needs 'moved' before it comes apart? What is the easy way to do this? Pictures?
Better to get advice before I hurt something... |
14-pin connector.......
Motorman, Are your referring to the 14-pin connector for the engine wire harness? The engine wire harness is connected to the chassis wire harness by the 14-pin connector located on the engine bay fuse panel. The 14-pin connector has the male and female sides (one side for the chassis and the other side to the engine). Look very closely at the 14-pin connector and you will see the split (male/female configuration). Use a small screw driver to start separating the two sides. Gradually work at both ends to separate them. Inspect the 14-pin housing/s, if they are cracked or broken, time to replace it. Keep us posted. Tony |
ROW '78 911 Targa
Besides the 14 pin connector Tony described there is the Connecto to the bottom of the CDI unit, there is a white T shaped 2 pole connector, and depending on the year there is a 3 pole VR connector all as part of the engine harness. All located near the CDI.
