Engine number help
Hi -
I have no reason to believe this isn't the original motor for my '80 SC but I was hoping someone could at least help confirm it. The number on the case is 6400504. The car is an early '80 with a build date of 10/79. |
I think the first. 0 is supposed to be a D.
Bruce |
As per Bruce suggestion its a D vice a 0.
The 0 could also be a C as in 64Cxxxx ( 82 model). Assuming its a D, 64D00504 is from an 83 model. The type is 930/16 The car was originally fitted with 630xxxx, type 930/07 or /09 (the VIN would confirm which one). |
Sorry for the blurry picture but it's the best i could get. The "0" looks consistent with the other one next to it. I'm going to head back out and see if i can get a picture of the type.
https://c1.staticflickr.com/1/424/19...661bc599_b.jpgUntitled by sicklyscott, on Flickr |
No dice. AC crap is in the way.
You really need the type because it look like the boys on the line may have had a few too many :D:):D
Just came across a post on another site, dude has a 1980 911 with engine serial number 6400313 with a car build date of 10/79. This seems to line up with what I have. I'll still try and get the engine type when I remove the AC but it won't be anytime soon.
Serial number 6400504 is correct for a 1980 SC, USA engine, type 930/07. The Serial numbers for SC engines changed from numeric to alpha-numeric in 1982 (i.e. went from 640 XXXX to 64C XXXX)
regards, al |
| All times are GMT -8. The time now is 01:47 AM. |
