Engine number help
Hi -
I have no reason to believe this isn't the original motor for my '80 SC but I was hoping someone could at least help confirm it.
The number on the case is 6400504. The car is an early '80 with a build date of 10/79.
1980 911 SC - Black on Red
Chronicles of my '80 SC: http://forums.pelicanparts.com/porsche-911-technical-forum/844949-chronicles-my-80-911-sc-91a0140491.html
Old 06-27-2015, 12:56 PM
I think the first. 0 is supposed to be a D.
Bruce
Old 06-27-2015, 01:22 PM
83 911 Production Cab #10
JJ 911SC's Avatar
As per Bruce suggestion its a D vice a 0.
The 0 could also be a C as in 64Cxxxx ( 82 model).
Assuming its a D, 64D00504 is from an 83 model. The type is 930/16
The car was originally fitted with 630xxxx, type 930/07 or /09 (the VIN would confirm which one).
Who Will Live... Will See
Old 06-27-2015, 01:54 PM
Sorry for the blurry picture but it's the best i could get. The "0" looks consistent with the other one next to it. I'm going to head back out and see if i can get a picture of the type.
Untitled by sicklyscott, on Flickr
Old 06-27-2015, 02:25 PM
No dice. AC crap is in the way.
Old 06-27-2015, 02:46 PM
JJ 911SC's Avatar
You really need the type because it look like the boys on the line may have had a few too many
Old 06-27-2015, 03:47 PM
Just came across a post on another site, dude has a 1980 911 with engine serial number 6400313 with a car build date of 10/79. This seems to line up with what I have. I'll still try and get the engine type when I remove the AC but it won't be anytime soon.
Old 06-27-2015, 04:41 PM
al lkosmal's Avatar
Serial number 6400504 is correct for a 1980 SC, USA engine, type 930/07. The Serial numbers for SC engines changed from numeric to alpha-numeric in 1982 (i.e. went from 640 XXXX to 64C XXXX)
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 06-27-2015, 04:42 PM
JJ 911SC's Avatar
Originally Posted by al lkosmal View Post
Serial number 6400504 is correct for a 1980 SC, USA engine, type 930/07...
Another strike against the Red Book... but Wayne rebuild book (which I should have check) has the 640xxxx listed as 1980.
Old 06-27-2015, 05:15 PM
