How To: Installing Bilstein Front Inserts on 89 Carrera with Boge Struts
Just went through this, installed bilstein sport struts on an 89 carrear with Boge factory struts and factory inserts. I found a lot of threads with partial info so thought I'd summarize here. Overall install was pretty easy. Benefits of a SoCal car, parts come off pretty easy.
1. Put front of car up on jack stands and remove wheels 2. Pull back carpet 3. Flatten lock washer on both sides strut bolts 4. Use 22mm socket to remove bolt, I used an impact (very light setting) to remove, thread nut back on on a few turns 5. Use a flange wrench to remove rubber brake line at the body, plug and put to the side. Tip here is use a board or something to press brake pedal about 2" or so, wedge against seat, I think I dropped 2 drops of brake fluid. This keeps fluid from flowing. 6. Pull off and unplug the brake sensor, put aside. 7. Put a blanket over fender, hang it below wheel well to keep from scratching fender 8. Pull damper down, guess is it should be easy, mine were destroyed after 25+ years, pull out and remove top cap 9. Get a big pipe wrench, unscrew the top cap, this requires some torque to remove. I put the strut top lightly back in the top mount for better leverage, pull the strut back out 10. Once the top is loosened, keep it just a few threads tight, get a massive number of rags, towels, plastic bags, make sure you have some sort of pan or something to keep the coming mess from getting everywhere. 11. Extend the shock, do this before removing from the body, will minimize the mess. I learned this on the 2nd one. 12. Unscrew the cap all the way and remove the insert. There is a sleeve that will come out along with the piston, dump the oil in this sleeve into a container and wipe off all the parts, put aside 13. Use a hand pump or, like i did, a bunch of shop paper towels to suck up all the oil INSIDE the damper. there is a lot. Probably took 10 towels rolled up. Basically lay 2 paper towels and roll them up, then just drop down let it soak up the oil, pull it out, flip around. i used a long nose pliars to grab the paper towel and a screwdriver handle to push down in the shock. Eventually it will be clean. Put these in a bag. 14. Drop the new strut in the upright, tighten to 95 ft lbs (TIGHT) with the spanner wrench or a pipe wrench. My shop made me a spanner that would fit from another brand of shock wrench. My shock came with 2 different top nuts, one inside, one outside. I used the outside only. 15. Put the cover on the top of the shock 16. Compress the shock all the way, (this requires some weight to do) work fast and get it in there and in the hole. You may need to use a screwdriver to lightly work the threaded portion up to get a nut on 17. use the old nut to pull the shock all the way up into the top mount, remove the old nut 18. Put the washer and the new locknut that came with the bilstein, tighten. i also hit this lightly with an impact (light setting) 19. Replace carpet 20. replace brake line, brake sensor 21. bleed caliper 22. Put wheel on and torque 23. Repeat for other side I think this covers all the steps. Not a hard job, a bit messy. First one took me 2x as long as the second :-) |
Like you said it is messy. Other than that nothing major. Thanks for doing the write up.
You forgot to reset the ride height.
I know when I went from Boge to Bilstein Sports on my car the front end say way up high when I finished. |
You don't need to remove the brake line, just remove the clip and push the line through the bracket so it doesn't get stressed. Raise the a-arm with a jack or set the car down on the tire to push the threaded shock top up enough to get the nut on. Do one side at a time or you will fight the sway bar tension.
I found the most recent thread about using Bilstein inserts with Boge struts. I picked up used inserts but the gland nut has inside threads and my 87 Targa Boge struts require a nut with external threads. Does anyone know where I can get replacements. It doesn’t appear to be very straightforward. Thanks!
http://forums.pelicanparts.com/uploa...1588964184.jpg http://forums.pelicanparts.com/uploa...1588964479.jpg I’m always amazed to see members of this forum with thousands of posts! Well after a little over 9 years on this 911 tech forum this is my 1,000 post. Many many questions. Thanks for all the support! Mike |
You received the wrong inserts. 3/85 Boge changed from an internal thread to an external thread. You need the later units.
Will they work if I can find the right nuts?
Yes. They often come with both sets, inner and outer.
Thanks guys!! The search is on. The gland nuts I’m looking for seem to be as scarce as hens teeth.
Ah the beauty of being on the West Coast! Frost warning here in Ohio. Just back in from covering Grandma Joni’s lilac. You know the saying when Grandma ain’t happy NOBODY is happy.
Would an inside to inside threaded adapter (previously known as female to female) work if worse came to worse? It would add length, OK or not?
Nope, Got to be the right part, any adaptor will not allow you to properly secure the insert in the strut.
http://forums.pelicanparts.com/support/smileys/wat6.gif |
Got it. Thanks! I suppose not as much a fuss over a male to male adapter.
I have a couple of new ones if you can't get them from bilstein.
Thanks John. I sent you a note. Appreciate the offer!!
Does anyone grease the shock insert or add oil into the strut tube? I seen some people do this. It doesn’t really make sense to me.
| All times are GMT -8. The time now is 04:11 AM. |
