porsher
aston@ultrasw.c's Avatar
Rear Coilover Install
I have installed ER rear coilovers (super product BTW)
They are a tight fit, which I kinda' expected. After 2 hours of track time the contact was plain to see.
This is the left side, the right is similar only less severe.
So the question is what to do about it?
I could take a little toe out, which would move the hub to the rear - better centering the spring, but I like the toe where it is.
I could beat on the tower, which I am not afraid to do, but I don't think I will get enough clearance.
My idea is to cut the tower as shown, move the sides apart and away, then weld in a strip to close the gap.
Access will be a PITA and I could end up welding my head etc so before I dived in I thought I would ask questions
The goal is to do it once and forget about it.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 12-20-2015, 08:22 AM
Did you use 2.25" or 60mm springs?
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-20-2015, 02:39 PM
Elombard's Avatar
What if you removed the entire "cup" fabbed up a new one on the bench with that as a template- opened up the holes in the cross member and welded it back in. Is there room in the cross member for a bigger 'cup'? You could even drop the ride height a little if you wanted.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 12-20-2015, 02:42 PM
Racer
winders's Avatar
Looks like a Hypercoil OBD spring. The coils at the ends, probably 2.25", are smaller than the coils in between.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 12-20-2015, 02:46 PM
Sell the ones you have and get some upside down coil overs . No cutting or welding required.
Old 12-20-2015, 02:57 PM
porsher
From Elephant Racing, "We use 2.25 inch Hypercoil springs."
79 928 Race Car
Old 12-20-2015, 03:39 PM
porsher
I could - I was trying to be as non-invasive as possible.
I want to end up with enough room that if I did raise or lower the ride height a tad I wouldn't have the same prob.
79 928 Race Car
Old 12-20-2015, 03:41 PM
porsher
Chuck, is it too late to send them back
79 928 Race Car
Old 12-20-2015, 03:42 PM
Racer
winders's Avatar
If it were me, I would fix the clearance issue and then replace any springs that have been scrapped up in the process. That would be both the main springs and the tender/keeper springs.
Scott Winders
PCA GT3 #3
Old 12-20-2015, 03:53 PM
porsher
In my experience Elephant Racing supplies a superbly engineered product, that doesn't actually fit my car. Great.
79 928 Race Car
Old 12-20-2015, 04:04 PM
Wer bremst verliert
JohnJL's Avatar
Hotbits offsets the top mounting bolt for this reason, and to allow more room for the remote canister hose.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 12-20-2015, 06:02 PM
You need a clevis kit so you can mount the shocks upside down, assuming these are safe to do so.
We fit these in the majority of cars with coilovers just for these reasons.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 12-20-2015, 09:31 PM
safe's Avatar
They have a version for the pre 72 tubs that has the springs further down, bellow the cup.
Even that was to tight for my -69 so I had to put the BFH to good use.
I think the BFH could fix your issue.
Magnus
Old 12-21-2015, 12:48 AM
Sboxin's Avatar
We used ER coilovers on our 1978 911SC race car with no fitting difficulty on the rear.
Could you put a spacer on the lower shock connection to the trailing arm to move the lower end inboard? A couple of washers should do it.
Also, sometimes the Porsche bodies are not always an exact fit - a few MM here and and few MM there . . . just sayin' - - We had to lathe down a wheel spacer for our Boxster by 1.5MM to fit some wide track tires on the rear end - - the body was off by that much from left to right side. .
It may be your car and not the parts . . .
We would still like to see you on track here in Phoenix some day,
Regards,
PS: Recently got a tip from Jim Hendricks - put the tender springs on top so they don't rub on the threads of the coilover adjuster.
2002 Porsche Boxster S Cobalt Blue/Blk/Blk
Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car
Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine
Old 12-21-2015, 06:19 AM
safe's Avatar
+ It would make them sprung weight instead of unsprung...
Magnus
Old 12-21-2015, 08:25 AM
Mahler9th's Avatar
In my experience, the clearance for these kinds of changes can vary depending on several variables. I just went through this with a major suspension change.
I got some suggestions from a good friend with pro level experience. He suggested I create more clearance with my hammer, and that I space the shocks inward with spacers on the lower shock bolts. I did so (probably about .150 inches per side).
My friend suggested I could space each side in as much as 1/2 inch if I needed, as long as I had a proper lower shock bolt.
No more clearance issue. No need for new springs or perches or upside down shocks. Easy, fast and cheap solution.
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 12-21-2015, 08:30 AM
Racer
winders's Avatar
Except that, if anything, it makes more of the heavier main spring unsprung weight so there is a net loss in sprung weight.....
Scott Winders
PCA GT3 #3
Old 12-21-2015, 08:31 AM
Cory M's Avatar
Try this before modifying the tub or parts. My Moton set up uses a spacer at the lower bolt to provide clearance and allow the shock to articulate.
Old 12-21-2015, 08:50 AM
non-whiner
mreid's Avatar
I used a 1/2" spacer at the swing arm mount.
"Too much is just enough."
Old 12-21-2015, 09:47 AM
Mahler9th's Avatar
One more thing that may be obvious but is prudent to add: interference here could affect handling.
In my case, the interference was the result of a change in spring thickness. I went from 550 to 700 pound springs. Even though the ID was the same, the OD increased slightly with the stiffer springs (larger diameter wire). That increase was enough to cause interference, which I noticed in handling on the track.
After using my hammer to improve the situation, I decided to ask my friend what else I might try, and he suggested spacing the shocks in. I added a washer and moved my tie downs inward which moved the lower shock mounts inward. It worked. I may need to do some fine tuning with a few more washers or spacers once I settle on final alignment and height specs.
With all of this it is important to know what you are using for lower shock bolts and ensure their condition is appropriate.
I should also add:
1. In my experience it is not necessary to toss springs that have paint scraped off.
2. The OD difference between Hypercoil and Eibach springs for the same rate are about the same. We have to remember that the spec is 2.25 ID, and that the OD will be affected slightly by coil thickness which is proportional to rate.
Mike
BMWCCA
NASA
Old 12-21-2015, 10:45 AM
