Rear lights- earthing
Hello
As with Porsches I have inherited an earth issue.
The problem I have is:
Oil gauge flickers in time with the indicators!
Brake and indicators both flash when either is activated
Question:
Anyone else had this issue with the oil pressure gauge and what earth connection is common if any?
The light fitting are the original ones which would be nice to clean and re use, but some one has chewed the screw heads.
What's is the easiest way to remove the damaged screws?
Also what is the screw diameter so I don't use too big a drill.
If I brake removing, are the aftermarket light clusters ok? Or to be avoided?
Cheers
Old 06-21-2015, 12:39 PM
Kroon Wire Harnesses
Which year is your car?
Specialized in Classic Porsche electrics
www.kroonwireharnesses.com
Check also our Facebookpage: https://www.facebook.com/kroon.wireharnesses
Old 06-21-2015, 12:55 PM
1892
Old 06-21-2015, 01:14 PM
Originally Posted by PWICK911 View Post
1892
1982 sorry
Old 06-21-2015, 01:15 PM
ROW '78 911 Targa
timmy2's Avatar
Please post a photo of the screw area.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 06-21-2015, 01:40 PM
I think you should check the ground eyelet first (brown wire) . Maybe the connection is bad due to corrosion ? The aftermarket one's i have seen so far were always low quality. Always better if you can save your original ones. A picture would indeed help which screws you are referring to.
Old 06-21-2015, 08:52 PM
T77911S's Avatar
i would look for some crossed wires.
check the light switch and emerg sw too,
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 06-22-2015, 03:49 AM
Any Tips for successful removal of Tail Light Assembly?
Found this thread on how to remove rear lights which will be my first job.
Old 06-22-2015, 01:38 PM
ROW '78 911 Targa
timmy2's Avatar
Ok,
Now it is clear what you are referencing. I though you were talking about the instrument light bulb holders and wondering where the screws are!
Use a Dremel with a thin cutting blade to cut a groove for a flat blade screwdriver if you can get in there for removing the screws.
The plastic aftermarket units aren't worth bothering with.
Dennis
Old 06-22-2015, 01:59 PM
T77911S's Avatar
i thought he was talking about the instruments too
RACE CAR:: sold
Old 06-23-2015, 04:51 AM
New-ish 911SC Targa Owner
pampadori's Avatar
In case someone else searches and finds this thread...
I had weird lighting issues on my 1983 because one of the tail/brake bulbs was incorrect. The previous owner had put in an 1156 instead of the 1157/7528 two filament bulb.
My symptoms were:
Brake lights not coming one when parking lights were on.
Front right turn signal bulb would illuminate when brake pedal depressed.
Old 06-29-2015, 10:53 AM
