PeckerHead Amps
Blind Lemon's Avatar
New to me and a wheel and tire question
Been mostly lurking for a few years wishing to find what I found......... locally known car. Its a 1974 2.7 with SC flairs. PO had kept it tagged, but is really set up for AX. It has 15 inch wheels with Hoosier 225/45zr15s all around. It's very "zippy" and fun to drive, but, I need to get some dedicated street tires and new rims as I want to keep the Hoosiers mounted on the 15s. It sets a little lower than 24".
In light of the "limited" availability of 15s and even to a certain extent 16s I am wondering if I should go straight to 17s? I have done searches and read most of post and that is pretty much my conclusion.
Opinions.
As far as tires go I am looking at the Dunlop Direzza ZII Star Spec and the Hankook Ventus R-S3. Sizes? Thats a hole'nuther post.
This will be a weekend very sunny day car.
Bob
Old 06-29-2015, 03:16 PM
Bill Verburg's Avatar
Opinions.
Bob
Part of the 'zippy' feel of the car comes from the short OD, l/w wheels and tires on the car, If it were mine i'd keep 15s, 7ET23.3 front and 8ET10.6 rear, use 205/55 or 205/50 fronts and 225/50 or 225/45 rears
the shorter and lighter the zippier
maybe 16s in 7ET23.3 8ET10.6 or 9ET15 w/ 245/45 or 225/45 x16 rears and 205 50 or 205/55 fronts these are just a bit taller and heavier
Bill Verburg
Old 06-29-2015, 03:39 PM
PeckerHead Amps
I do want to keep the short Hoosiers for AX and maybe some track time, but was hoping for some taller tires for the street and highway driving.
And thanks BV.
Bob
Old 06-29-2015, 03:45 PM
I also run the Hoosier 15s for AX.
I recently put the Bridgestone RE-11s on 7/8-16s. Excellent street tire IMO
Old 06-29-2015, 06:21 PM
Driver, not Mechanic
OT: are your RE-11s the same as the new ones on TireRack.com with 200 tread wear rating?
I have older RE-11s going on 3 years with 180 tread wear. Wondering if I should get RE-11s again (moving me down a class in AX, not that I care) or go with the S-02s with rating of 140.
Old 06-29-2015, 07:03 PM
Yes the 200 TW
I gave no experience with the 140s, so really can't compare.
Old 06-29-2015, 07:59 PM
