what's my noise? 78 911
It's hard to describe, a metallic rotational rubbing sound almost. not like brake pads rubbing, but more like a high pitched humming when driving slowly.
Only when car is rolling or driving and it does not affect the noise if the brakes are on. ? Thanks,
___________________________ 1978 Jeep CJ5 (red) 78K 1978 Porsche 911 Coupe (silver) 89K 1984 Porsche 944 (red) 71K 2004 Chevy Tahoe Z71 (silver) 74k |
Reiver
That, my friend, could be a multitude of mechanical things....where does it originate from, is it rpm specific (up/down) of constant.....iotw, much more info required.
De Oppresso Liber Strength and Honor 5th Legion |
Nothing to do with speed, nor rpm. it seems it is in the front wheel area but even split. i would assume wheel bearings would sound more screechy. this is is really i high pitched hum of sorts. but it is consistently he same at slow speeds and is fairly loud. has nothing to do with engine at all. it does it when the engine is off and is just rolling.
Could it be the sound you get when pads are worn. Some pads have a warning sound like what you described
Ernie |
Brew Master
Troll Hunter
My first thought was wheel bearings. For Pete's sake, jack the front and spin the wheels and push and pull them to see if you hear anything, instead of just posting a question.
1978 SC Coupe, Gris Argent Metallic Silver 1988 FJ62 Blue/Gray 2020 M2 CS |
