nick-moss's Avatar
917 brake caliper?
Can anyone identify this brake caliper?
The mountings are 12mm spaced at 3 1/2 inch, the 4 pistons are 38mm, the disc thickness allowed would be about 30 - 35 mm.
There appears to be a date stamp on the bridge: 28 2 68
Nick Moss - RGruppe #318
early911.co.uk
Old 11-10-2002, 08:18 AM
Bill Verburg's Avatar
It appears to be similar to these calipers on a 908
Bill Verburg
Old 11-10-2002, 08:37 AM
One more,
There are differences though, your pic is a 3 piece ala the 930 caliper, rather than the monobloks on the race car. The piston sizes match that used on the 930 front as does the mount. My guess is that it's a prototype of the 930 caliper
Bill Verburg
Old 11-10-2002, 09:05 AM
nick-moss's Avatar
Thanks Bill
I haven't seen detail pics of 908 brakes before. I had a look at the Vehicle Craft site that you mention on your own site and the 930 caliper certainly looks very similar to the items I have.
930 caliper
early911.co.uk
Old 11-10-2002, 09:32 AM
Early_S_Man's Avatar
Porsche Crest
Nick,
Per Ludvigsen, p. 667, THAT IS an original 917 caliper!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 11-10-2002, 09:43 AM
nick-moss's Avatar
Yup, I have that picture too.
Just looking for confirmation from elsewhere. Does anyone know if the 917 used the same size calipers and pistons front and rear?
early911.co.uk
Old 11-10-2002, 09:47 AM
nick-moss's Avatar
This is the picture from Karl Ludvigsen's book that Early_S_Man refers to above.
early911.co.uk
Old 11-10-2002, 10:00 AM
Porsche Crest
Nick,
Paul Frere mentions the use of 34 mm and 38 mm pistons in a set of revised Ate calipers on p. 24 of Porsche Racing Cars of the 1970's. The 'originals' used 34 mm pistons all around ... p. 22. Are the bridge bolts made of Titanium?
Warren Hall, Jr.
Old 11-10-2002, 10:21 AM
nick-moss's Avatar
The saddle is aluminium, the bolts are steel.
I think these will do the job on my 3.0RS replica!
early911.co.uk
Old 11-10-2002, 10:41 AM
The very few first '78 3.3 911 Turbos had the ATE 4 piston calipers (the same as on the 917) instead of the Brembo ones, because of a delay with the Brembos.
These could well be a pair of them.
GeorgeK
Old 11-10-2002, 12:51 PM
Doug E's Avatar
So what's the story behind this original caliper?
Doug
'81 SC Coupe
Old 11-10-2002, 12:57 PM
rallyman's Avatar
Bill, NICE website, first time I've been there! It answers almost all the questions I ever had about 911 brakes!
I love the early 911's and would love to own one one of these days so I lurk over here alot......
One question - is it possible to fabricate new mounts/modify the existing mounts on the rear trailing arms for the 930 calipers - as opposed to modifying the calipers?
Thanks!
Craig.
"Don't close your eyes before the crash....you'll miss the best part!"
Old 11-10-2002, 01:33 PM
rallyman's Avatar
Thanks!
Craig.
Old 11-10-2002, 01:45 PM
nick-moss's Avatar
I have just bought 4 of these calipers to fit to a '74 3.0 RS replica. If they really are 917 calipers then I don't want chop them about to fit non Turbo trailing arms. The fronts are no problem as they fit straight onto my Bistein struts with Turbo hubs and calipers.
Thanks GeorgeK, I hadn't heard that before about the ATE calipers. There are no manufacturer markings on these calipers, just the possible date stamp, and a small circle with GT13 in it.
One caliper has 411x9 cast into it
early911.co.uk
Old 11-10-2002, 01:55 PM
The '73 2.8 RSR and '74 Carrera 3.0RS used a finned version of your caliper called a "type 917" now I see where the name came from. This was the first use of those types of caliper in a 911 R model. The one piece calipers must have predated the 917 3 piece units. What size on the rear pistons?
Nick, Do you mind if I use your pics at my brake site? They would be an interesting addition.
rallyman, thanks,
The trailing arms can be modified but aren't any longer because it's so much easier to modify the caliper.
Bill Verburg
Old 11-10-2002, 06:26 PM
nick-moss's Avatar
Hi Bill
I too have found your site very useful. Please feel free to use any of the images as you wish. I will put some more on a web page for you in a couple of days
early911.co.uk
Old 11-10-2002, 10:14 PM
Thanks Nick! Good luck w/ your project. The Carrera 3.0 RS was always my favorite coupe. You guys are starting to get me thinking about a coupe project of my own
Bill Verburg
Old 11-11-2002, 05:40 AM
Here's a drawing of the only Ate 4 piston caliper that has 3.5" mount that I could find.
Nick, what pads are you going to use, what pistons are in the rear set, do the rears have the same mount as the fronts?
I've added your pics to my brake page and would like to update the data section.
Bill Verburg
Old 11-11-2002, 11:29 AM
nick-moss's Avatar
Bill
all 4 calipers are the same, with 3.5" mountings and 38 mm pistons.
They are not the ATE calipers pictured.
I hope to use Turbo 3.3 pads.
early911.co.uk
Old 11-12-2002, 02:37 AM
nick-moss's Avatar
Bill
I have posted all my photos at 917-brakes.html
early911.co.uk
Old 11-12-2002, 01:23 PM
