1970 911 T
Torsion bars stuck
maybe someone can help ;
I am in process of removing my rear torsion bars ( 1970 911T ) ; I removed
all the bolts but cannot get the torsion bars out of the outer spring plate cover.!
I drilled a hole at the end and tried to push ( hammered ) the torsion bar out but no luck...
does anybody already encounter this problem and how to go about it ???
Francois
Old 05-28-2010, 09:08 AM
MBruns for President
JeremyD's Avatar
pry bar and work it off
Old 05-28-2010, 09:21 AM
1970 911 T
torsion bars
Thanks Jeremy ,,, there is not much room to use a pry bar or even move the assembly around. it only move about 8 inches in & out.
I am thinking of cuting the t-bar cover,,,,,,,,,,, but that would be the last solution
Old 05-28-2010, 09:31 AM
pete3799's Avatar
The outer spring plate cover should pry off.
I suspect it's the spring plate itself your having trouble removing.
A three jaw puller and heating the spring plate should do it.
Pete
79 911SC RoW
Old 05-28-2010, 09:32 AM
Midwest R Gruppe
t6dpilot's Avatar
I just ran into this problem myself. Very, very frustrating to say the least. Soak it in PB Blaster or equivalent for several days and multiple applications. You will need two people for this. Heat the TB cover with a torch - you will need to get it pretty hot. While one person holds the spring plate against the chassis, the other should hammer out the TB using a punch through the access hole. It takes some pretty good whacks, but should eventually come free of the spring plate.
Next fun part - removing the bushings.
Scott
69E Coupe 2.2S LtWt
73.5T Coupe
Old 05-28-2010, 09:36 AM
Free will is doing what we must joyfully.
Jung
'68 912 Coupe
'82 SC sunroof
Old 05-28-2010, 09:37 AM
I just did this a couple of weeks ago on an SC.
I used a map gas torch to heat the spring plate and liberal doses of PB inside the t-bar/spring plate joint to dissolve the rust. I needed several cycles of heating and cooling before I was able to hammer the T-bar out of the spring plate. I drilled a hole in the end cover and used a flywheel bolt as a drift to pound the t-bar out. It took some heavy pounding to hammer it out.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
1970 911 T
torsion bars
WOW , lots of experience here........ I will try the heat & Hammer solution.
Thanks a bunch .
Francois
Old 05-28-2010, 09:49 AM
Can you buy the swaged / staked in cover disk (shown removed with the puller) A friend has ask me to design an make one (maybe aluminun turn on lathe & press in) as he is missing one??
I just had what looks like minor problem stripping a 68 and drilling thry and driving out with a punch worked. I plann on welding the hole up and grinding smooth.
Buying one I am sure would be easier than making one and this does not look to be so uncommon of having one missing?
Regards
Old 05-28-2010, 01:02 PM
zl0ca's Avatar
Originally Posted by djdsc View Post
how did you get the little plate off the spring plate to get to the t-bar?
Old 06-29-2015, 06:45 AM
Did this a few weeks ago. It took perseverance to get it off. Here is a tip - there is some flex in your bodywork that allows you to slide the spring plate off the torsion bar when you get it loose. I think we spent an hour trying to loosen it.
Wait till you try to fit it all together with new bushings. I used longer bolts and the cover plate to try and put it back together swapping the bolts for slightly shorter ones until I fitted it. I ended up bending the cover plate. Took it all apart and then used a dremel to clean the inside of the torsion tube to get a better fit.
The "How to do it" articles seem to skip over the nasty bits.
Old 06-29-2015, 07:00 AM
zl0ca's Avatar
Torsion bars stuck
I'm not sure if I follow your advice. Are you saying use the chassis as a lever?
Old 06-29-2015, 11:05 AM
Drill a hole.......
Drill a small hole at the center of the disc. It is not welded but forced fit. And pry it off. I used some JB weld to patch the hole after separating the TB from the spring plate. To separate the stuck torsion bar, DJDSC's technique works great!!!!! I've used this technique many times over the years with heat and penetrating oil. Find a suitable size two or three-arm gear puller and don't forget to remove the access cover for the torsion bar.
Tony
Old 06-29-2015, 11:32 AM
A while back I had to cut a t-bar in half with a disc cutter to get the spring plate out. I had a used pair, so no big loss.
206 637 4071
Old 06-29-2015, 02:18 PM
No,
Do not chassis as a lever. It just took lots of back and forth pulling on the unit to remove it. A major job. Nearly gave up as thought there is no way it coming out. But it did. When you have it loose, there is insufficient room between end of Torsion bar and the body to remove the spring plate. However you can pull the body panel out a little to then remove the spring plate.
I also found heating is the way to go to loosen bolts etc. Tried the other methods but no luck.
Old 06-29-2015, 08:26 PM
zl0ca's Avatar
Tony
This technique worked so well that I drilled a hole on the otherwise to avoid the possibility of a problem. I did ended up lowering I it and it settled too low. Attempt #3 to come
Old 07-03-2015, 04:53 PM
zl0ca's Avatar
After my final attempt I have it dialed in at 24.5.
Old 07-04-2015, 05:09 PM
