What's the best way to remove windows
Was wondering if anyone could tell me the appropriate steps to remove the door windows in my 1980sc targa. Is it best remove glass before regulator? Thanks
You've got your door slot seals out right?
Yes there out.Tried removing window per Bentley book and had no luck. Anyone?
Pretty sure you have to remove window frame.
I took my window out recently. Basically you are going to be taking the whole door apart to do it. There is a way to slide the window out with the quarter window in place, but GOOD LUCK.
I took everything off. Regulator, quarter window, window slider. I angled it out up top by tilting it carefully. NO scratches! The carnage! But it was actually pretty easy/fun. I had to take it all apart because the window was in the way of the door latch (broken, got a new one!). http://forums.pelicanparts.com/uploa...1433565849.jpg |
I carefully followed the directions and there's no way window is going to slide out.I guess it's time to tear the whole thing apart.
This may help.
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/756722-door-disassembly-how.html Cheers, Johan |
Finally figured it out, must be a 1980 targa is a little different than other window assemblies. Thanks for everyone's help I appreciate it.
Maybe my car is different, I don't have a WINDOW frame!! It's a 79 SC Targa! What the!!!
Edit; Nevermind! Targa's don't have window frames!! :) |
| All times are GMT -8. The time now is 11:39 AM. |
