What's the best way to remove windows
Was wondering if anyone could tell me the appropriate steps to remove the door windows in my 1980sc targa. Is it best remove glass before regulator? Thanks
Brew Master
You've got your door slot seals out right?
Yes there out.Tried removing window per Bentley book and had no luck. Anyone?
Pretty sure you have to remove window frame.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
I took my window out recently. Basically you are going to be taking the whole door apart to do it. There is a way to slide the window out with the quarter window in place, but GOOD LUCK.
I took everything off. Regulator, quarter window, window slider. I angled it out up top by tilting it carefully. NO scratches! The carnage! But it was actually pretty easy/fun. I had to take it all apart because the window was in the way of the door latch (broken, got a new one!).
Brew Master
I carefully followed the directions and there's no way window is going to slide out.I guess it's time to tear the whole thing apart.
Uncertifiable!!!
This may help.
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/756722-door-disassembly-how.html Cheers, Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
Finally figured it out, must be a 1980 targa is a little different than other window assemblies. Thanks for everyone's help I appreciate it.
Maybe my car is different, I don't have a WINDOW frame!! It's a 79 SC Targa! What the!!!
Edit; Nevermind! Targa's don't have window frames!!
