-   -   Installing 95 993 3.6 into 69 T/RSR (http://forums.pelicanparts.com/porsche-911-technical-forum/873290-installing-95-993-3-6-into-69-t-rsr.html)
rennch 08-30-2015 02:15 PM
spacewise, this front cooler looks almost impossible to install. There's just not enough room up there.
quattrorunner 08-30-2015 02:31 PM
You'd need to cut the front trunk area out and put a oil cooler panel there for that otherwise add one in the fender. If you can weld do the front cooler.
mreid 08-30-2015 02:32 PM
I'm only running a front cooler in my 1974 with 1995 3.6. Never gets hot in south Texas heat.
rennch 08-30-2015 02:35 PM
Can I get away with just the one fender cooler on a trip from SD to Monterey? Then add an additional fender or front mount after I get back?
rennch 08-30-2015 02:36 PM
I'm pretty adamant about not cutting anymore chassis. I'd rather put dual fender coolers in there.
quattrorunner 08-30-2015 02:37 PM
That's good to know. Front mount is better as there is lots of fresh air there. Fender needs help.
quattrorunner 08-30-2015 02:47 PM
If you can't cut the front then it needs to be fender mount. How big is the rx7 cooler? Perhaps we could do some horse trading.
quattrorunner 08-30-2015 02:53 PM
I don't know about just the fender cooler.
Trackrash 08-30-2015 04:48 PM
You should talk to Kinninger. He built the blue "smurf" car that AXs at Qualcom. He works at Black Forest.
I have an RX-7 cooler mounted to the front of my '71. I did not mod the tub and it fits in my front bumper. Works well. Plumbing is tight on the long hoods due to the battery box. I actually have room for a larger cooler.
http://forums.pelicanparts.com/uploa...1440978368.jpg
Not my car but it shows the plumbing.
http://forums.pelicanparts.com/uploa...1440978481.jpg
pors1968 08-30-2015 05:11 PM
Always tought the RX7 cooler were good enought for 3L not for 3.6
quattrorunner 08-30-2015 05:31 PM
3.0 has engine Cooler too. 3.6 does not.
arrivederci 08-30-2015 06:17 PM
You will need two. I have one in each fender and am considering adding a fan to one side for traffic situations. I wouldn't risk running with just one cooler.
rennch 08-30-2015 11:49 PM
Noted. Thanks!
froggert 09-01-2015 07:30 AM
I ran just the single stock carrera oil cooler for a little while. It was fine in cooler weather or while moving but not sufficient while stuck in traffic in 90 degree temps.
rennch 09-01-2015 08:11 PM
I'm told that I can use the RS bumper, but I have to really trim it to get it to work.
Does anyone know if I can use the stock 993 engine tin? I can't seem to find any good 3.2 tin at the moment.
safe 09-01-2015 11:14 PM
You need to modify them a bit.
Chop down the rear section so its level with the side tins and remove the heater duct.
http://forums.pelicanparts.com/uploa...1441173685.jpg
I also needed to chop down the front section half an inch, not the whole length but until the curve at the ends.
http://forums.pelicanparts.com/uploa...1441173836.jpg
From the curved section I needed to extend the tins to fit the seal.
http://forums.pelicanparts.com/uploa...1441174002.jpg
And since I'm not keeping the power steering pump a big hole was left that I needed to fabricate a new tin for.
http://forums.pelicanparts.com/uploa...1441174347.jpg
http://forums.pelicanparts.com/uploa...1441174097.jpg
Not sure everyone needs to cut the front tins, I have a G50 and maybe the engine isn't in the exact same position as someone with a 915.
rennch 09-01-2015 11:24 PM
Magnus...THANK YOU. It's exactly what I needed. You rock.
safe 09-02-2015 12:14 AM
Your welcome!
PcarPhil 09-02-2015 06:22 AM
Michael,
Keep in mind that Magnus is also using the 993 engine console and crossmember. Fitment changes quite a bit when using a 3.2 engine console and crossmember.
You'll probably go with one of these setups:
964/993 tins (modified) + 964/993 crossmember (modified) + 964/993 engine console + 1" spacers above crossmember
or
3.2 tins (modified) + 993 tins (donor pieces) + 3.2 crossmember + 3.2 console + single or double row crank pulley
safe 09-02-2015 06:48 AM
Originally Posted by Kaefer (Post 8777653)
Michael,
993 tins (modified) + 993 crossmember (modified) + 993 engine console
or
Well, 964 console and crossmember (modified), but youre right.
I also have a spacer (about 1 inch) between the crossmember and body. Otherwise the side tins would hit, the intake would not fit under the parcel shelf, and the gearbox would hit the shock tower crossmember.
I think I have the engine in the right place, maybe I should use slightly thicker spacers.
Should have raised the crossmember when I was welding on it... Maybe I'll redo that.
