Installing 95 993 3.6 into 69 T/RSR
Hi all. I thought I’d combine my threads into one unified one so y’all can follow along with this install. Hopefully it will be of future use to pelicanites. This all happened rather quickly. I decided to sell my PMO’ed 3.0 engine because it was going to be too pricey to try to build the 300 hp motor that the car deserved. I put the motor up on Pelican, and it sold in hours. Then a super clean 3.6 kind of fell into my lap for a great price, and it was located close enough to drive and grab.
When I was asking which engine I should get, Bill Verburg responded with these great bits of into, reposted here in case people want to know which 3.6 does what, and which are easier to instal (This is 2 quotes merged together)l: Quote:
My motor is a 1995 993 engine. It’s just in the back of the truck now as we drive back down to San Diego. I have no other info about it, but I’ve left a VM for the guy that owned it before the gentleman I bought it from. Overall the engine looks great. No oil leaks anywhere, and it’s complete except for the pulley side engine tin and the cats/muffler. The price was right, so I didn’t complain too much about it. As for the conversion, there are two main sources to get the parts and knowledge we need to do the swap. Steve Timmons at InstantG's Home Page and Patrick Motorsports. Steve is the genius home-brewed engineer, and Patrick is the dialed in race shop. I’ve heard varying stories of working with each of them. Steve has the temperament of many engineer genius types, but will also customize and help you through any problem you have. Patrick is more corporate, but are used to bulletproof race car builds. They may not have as much time to spend with you, but their engineering is very sound. A third option, and the one I'm going with, is to work with Jae Lee of Mirage International here in San Diego. He's sort of known as a suspension guy, but he's also the guy that built over 30 engines for Singer. (!) I've never seen a more meticulous engine builder or a more savvy Porsche engineer. I know with him at the helm, this thing will turn out amazing. As it sits, I’m going to be getting a few pieces from Instant G, a few bits from Rothsport, and a few bits from Patrick. Here’s what my list looks like, as well as some questions I have about the install: Wiring Harness Adapter Flywheel Throttle Cable Single Pulley Power Steering Block Off Cold Air Intake 3.0/3.2 Engine Tins 3.0/3.2 Pulley/Engine Console External Oil Cooler install. Wiring Harness Adapter - They make a special adapter for the wiring harness, but it adapts so the 14 pin connector. I have to adapt it *again* to the 6 pin that the 69 911 comes with. (It’s unique to this model year) If you get one of these engines, make sure you check to see if the wiring harness has the updated version (There was an update from Porsche on it) installed. It should cost $100-$200 from your local dealer. Flywheel - I’m told the really lightened flywheels have a tendency to stall the 3.6 (at least the 95) out, so it might be better to go mid-light (about 18 lbs) on it, vs. the 38 lb OEM version Throttle Cable - Both instant G and Patrick make one. Most say the Patrick is MUCH less flimsy than the Instant G version, though there are lots of people that have used the IG version for many years with no problems. There’s also another option which is to modify a 964 clutch cable. All of them require trimming or reducing/removing the throttle stop under your accelerator pedal to achieve WOT. Single Pulley - This converts the multiple pulley (with A/C) motor to a standard single pulley setup so if your belt breaks, your alternator light will properly light and tell you so. Power Steering Block Off - Self explanatory, as the 69 didn’t have power steering equipped. Thank god. Cold Air Intake - Replaces the giant airbox on the motor, and has a much cleaner (and racier) look. Engine Tins and Console - The 3.6 engine crossbar is different than the 3.0/3.2. The move is to either modify the Original by welding some bits to it and relocating the holes (there are threads on this) or sourcing an earlier style version. I’m going to go with the Rennline RSR crossbar, and I still need to source the console/pulley cover. As for the tins, apparently you can use the 3.6 back and sides (it has the holes for the 2nd set of plug wires and use an earlier front engine tin. (I still need to source this in case you happen to have one) Oil Cooler Install - The 3.6 does NOT have a built in Oil Cooler like the 3.0 and 3.2, so you have to make sure you plumb up external cooling. I have a Setrab (going in a fender) and an RX7 (going in the front) cooler that I’m going to run in series. I have a set of hard lines being delivered today, and I’ll need to modify from there. Usually you have to buy two hard lines for the 3.6. One of the old school lines that loops around the transmission, then another hardline to connect to the hardlines that run up to the front of the car. I’ll need to fabricate for this part, and I’m looking forward to getting a nice cool engine. I’ll also need to make sure my oil temp sensor matches the early gauge in my car. That’s what I’ve got so far. Will keep you updated. http://forums.pelicanparts.com/uploa...1435968743.jpg |
The Victim.
http://forums.pelicanparts.com/uploa...1435968968.jpg (We've come a long way!) http://forums.pelicanparts.com/uploa...1435969084.jpg |
For those of you smarter than me...would this be an upgrade for this motor?
Looking forward to this. I'd love to do a 3.6 on my "80, curious to see the difficulty level.
i've long forgotten about this but BillV has a good point about the harness. it is a good time to swap the harness if it is original while the motor is out. the original is a bio-degradable harness and is on its way for a catastrophic failure. order the part with recall specific p/n 000.043.204.61 (regular p/n 993.607.016.15) so that you get it cheap.
i love the look of your car. beautiful. |
After investigating the engine s/n, it was determined this was a late 94 U.S. Spec 964, engine, but has all of the 993 bits (plastic valve covers, 993 intake) there.
Here's the reference in case anyone needs it: http://images.tapatalk-cdn.com/15/07...dddd65b1ff.jpg Sent from my iPhone using Tapatalk |
Progress today. My lovely 3 liter came out for the last time. This is how a Porsche hot rod driveway should look on a weekend day:
http://images.tapatalk-cdn.com/15/07...412b062e44.jpg Now I have an empty engine compartment. What do I keep and what can I get rid of? MSD? Anything on the left fuse panel? http://images.tapatalk-cdn.com/15/07...7032188793.jpg http://images.tapatalk-cdn.com/15/07...5b40afe06a.jpg http://images.tapatalk-cdn.com/15/07...9b47e3fdc4.jpg I *really* want to dial in the engine wiring this time. Any suggestions? Sent from my iPhone using Tapatalk |
Megasquirt!!!
For dialing in the engine wiring pull the through body harness and have me build you one that is similar to the '70 and up that eliminates all the right side firewall connections.
Then your conversion harness will be 14 pin plug and play. May want to get a '70-'83 rear engine fuse panel for it. |
Good idea Dennis.,
I stack my cars on top of each others!
Removed the engine for a new clutch and LSD yesterday. http://i1037.photobucket.com/albums/...ps9zxzqrsr.jpg The car on the top is my -69 that will recieve a 3.6 engine soon. I'm having some engine harness issues like you because of the 6-pin connectors. Keep us (me) updated about the progress there. If you got a working wire diagram for the converter please post! :) |
Need to follow this thread, looks great!!
Looks like fun.
Easy enough to change to 993 MAF and computer or maybe a good 964 specific MAF. By the way, the intake runners are exactly the same. Take a shot of the back of it so we can see what air measuring device it has.
My next task is to engineer brackets to mount a fender mounted Setrab, and a front mount RX7 cooler I have. Would love to see some of your engineering.
Hello Michael
The car is looking great! Erik Black |
There are a couple of other differences between late model 964 and the 95 993 engine - hydraulic lifters - and the heads are drilled 4 holes (exhaust ports) not two so it is easy to change the exhaust studs The 95 engine made more hp than the 964 engines. jim
Erik, I'm honored that was your first post!
Pricing Matrix
I've put together a little pricing matrix so I can keep track of what I'm spending where. It's incomplete, but shows what each source is charging for similar items. If you see that I'm missing something, or know a price for something I've missed, please let me know.
Jae = Jae Lee from Mirage International. He typically fabricates all the parts necessary for the install, but that comes with a bespoke price as well. http://forums.pelicanparts.com/uploa...1436246467.jpg |
Decisions, Decisions
So, I've been doing research for days on what parts to get where, and here's where I've landed so far. If you see any room for improvement, let me know.
Flywheel - Patrick Motorsports (sounds like that's where everyone gets it) - $370 Clutch - Unknown if needed. Engine Crossbar and Cradle - Sourcing 3.0/3.2 from Pelican. Will raise engine to same level as 3.0. Engine Tin - Sourcing 3.0/3.2 from Pelican Camshaft/Power Steering Block off Plate - Patrick - $75 Oil Pressure Sending Unit - Pelican Cone Air Filter - Timmons - $195 Transmission Studs - ? Pelican or Timmons Oil Feed Pipe (instead of external cooler) - Timmons (Patrick's is very $$) - $145 (any other options?) Accelerator Cable - Patrick or Jae Lee custom. - $290 - (Timmons is too flimsy) Single Pulley Conversion - Timmons - $139 (vs. $385 at Patrick) Ignition Coil Mount - Patrick or Jae Lee Custom - $120 Wiring Harness Conversion - Timmons or Custom (Timmy2) $184 (vs. $395 Patrick) Oil Crossover Pipe to thermostat - Pelican Oil Crossover Pipe from Engine - Pelican Headers - Using 993 OEM headers Muffler - Looking for Sport muffler AC Bracket Removal - Custom |
Was in Portland for a conference, manage see a vintage race at PIR, and stopped by the Rothsport racing facilities. Jeff, Carl, Earl, Scott and the others have put together such an unbelievably first class facility. It's just eye candy everywhere.
I picked up a few bits for my conversion. Oil tube extension, single pulley conversion, power steering block off plate, and a couple other juicy bits. http://images.tapatalk-cdn.com/15/07...1f6d4e57d0.jpg The bad news? Turns out I can't use my current transmission (7:3:1 mag case from a 72 911). So, I'm now in the market for a 915 from 82-86. Drag. Sent from my iPhone using Tapatalk |
seems you enjoyed your stay in Portland! Great timing catching the vintage at PIR too. Congrats!
But the 7:31 R&P is too weak for a 3.6. I'm fitting a G50 into my -69 and that is a proper head ache.... |
Excuse my ignorance, but have you considered installing an engine mounted oil cooler? Is that a viable option?
Great build. Makes me wish I was still in SD.:cool: |
Still looking to source 3.2 engine tin and crossbar/console
http://i1037.photobucket.com/albums/...psa8zf3ayg.jpg http://i1037.photobucket.com/albums/...pslybjoqkr.jpg |
Congrats with your 3.6 project.
One day, I would love to do the same. |
UPDATE: sorry it's been forever since I have updated this thread. There's been a LOT of parts collecting.
This week I've been working on mounting my first oil cooler. I will have one of the fender, and one in the front bumper. Below are pictures of fabricating brackets for the fender mounted oil cooler. http://images.tapatalk-cdn.com/15/08...deabb47ad7.jpg I do use cardboard to mock up, and 1 inch flat steel to make the brackets. I'll put 90 degree outlets on the cooler and run the bumper mounted one inline. http://images.tapatalk-cdn.com/15/08...8488c1fb4a.jpg Here are the brackets, pre paint. http://images.tapatalk-cdn.com/15/08...4415a37fe8.jpg Using high temp engine enamel. http://images.tapatalk-cdn.com/15/08...f6262544f5.jpg Painted and installed. Tomorrow I'll work on fabbing the rx7 cooler in the front. http://images.tapatalk-cdn.com/15/08...4bcd7709e3.jpg http://images.tapatalk-cdn.com/15/08...e2336bd18e.jpg http://images.tapatalk-cdn.com/15/08...3f1ab19f72.jpg http://images.tapatalk-cdn.com/15/08...f6fe49ae96.jpg It's SUPER solid. Very excited about it. Sent from my iPhone using Tapatalk |
It's fun making functional important mods. That one looks good too. Make sure to block off as the factory did. You'll need it and a fan too.
How did the factory block it off?
Here is a picture of how they do it but your cooler is custom so you'll need to make some sheet metal block off to fit your application. Should be a tight seal from both sides of the cooler. You don't want air to choose simplest path because that's not through the cooler, it's around it.
http://www.pelicanparts.com/catalog/images/oil_circ/lower_stone_guard.JPG |
I've got a separate thread on wiring the 1995 motor into my 1969 Chassis as well: http://forums.pelicanparts.com/porsche-911-technical-forum/878918-wiring-3-6-into-69-911-help.html
Question for you experts. My plan is to run the Setrab in the fender, then an RX7 Cooler in the front. Do you think the RX7 Cooler is necessary? Or will the Setrab do ok? Sea Level car, not a track car. (Autocrossed)
You're doing away with one cooler already. One with a fan. I promise you need two. And you'll want to put a fan in the fender one. I think you'll be fine with two. If you went to Vegas there would be no doubt you'll want at least two. I've gone through this with a turbo in Vegas but even in cool weather it was clear the second fender cooler was wanted.
So you're suggesting to do another fender vs the front rx7? I have the bumper for it, and it's already been modded.
No, front cooler is fine.
Actually it's better. |
| All times are GMT -8. The time now is 01:33 AM. |
