Interior overhaul cost
Im trying to redo the interior of my 82 sc and trying to figure out how much round about it will cost for new material if i install it myself.
All of the leather and carpet surfaces including recovering seats. ![]()
82' 911SC Targa |
Interior redo
I pulled everything, cleaned up most of it. Pulled and installed dash, all interior, all new seals,
Had help pulling/installing windows Paid for carpet, headliner install Paid for sunroof removal/install/cleanup Includes repairing dash, re-wrap wheel, repair door pockets No material from kits, all cut and sewn from leather hides, vinyl dyed to match Spent around $7K total, all materials, labor, dye work, powder coating, |
Black and Blue
You might be better off sourcing parts from classified ads and then bringing it all together with a color change and new carpet via leatherique. You can freshin up a lot of the other parts youslf with a little work. I'm guessing you could spend a lot of money...a little bit of money...or some money
I'm personally very impressed with the leather rejuvinator fro leatherique... Save what you can and go from there. Maybe a prototipo instead of trying to fix the stocker. Also...big surprises can be found under the leather if you have leather covered door tops and kneepads... My leather was toast...but the plastic underneath was perfect black. Keep us posted...I'm in the middle of an overhaul myself. I keep eyeballing the singer lookalike seats from gts classics!
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
Right now i have a quote from worldupolstery for $4k. Wasnt sure if that sounded right but it looks like it is correct.
82' 911SC Targa |
Then come seats and like you I was set on GTS classics (they are even local to you and I) but from the pictures I am seeing and comments on the internets, I don't think they are worth the $. The BF Torino seats are cheaper even coming from Italy and the fit and finish look better than GTSC IMO. Tho they don't have singer clone seats if that's what you got to have. The exchange rates are favorable (thanks Greece) and we take 20% the price since no VAT (I believe) you can get nicer seats for way less than GTSC.
-70' 911T -in resto - (runs after 25+ years) -74' 914/4 - race car - SOLD - |
SC Interior
I replaced the headliner, carpets, seats (with Corbeau seats), door panels (with RS type), deleted the rear seats and console. Total cost for parts and labor (headliner) was around $3K. Here's a picture:
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
winter
Check this out.
While I agree with those who have posted that the classifieds can be a good source for upgraded and potentially nicer interior parts (this is the route I went), it's hard to argue with what this guy accomplished on a DIY budget + passion and commitment: Complete DIY Upholstery 1984 Regardless of which path you take, I'm sure you will easily improve what you have. But you knew that already! Good luck and post some "after" photos.
Tom '76 Targa |
I have done a complete gut of the interior on my '77.
Removed all old glue, paint etc...basically scrubbed down to bare metal. Primed and sprayed with POR. Wurth GM OEM sound deadening pads New square weave carpet kit Back seat delete. Original seats - completely redone / updated / upholsetred by GTSClassics (Stefan) Re-upholstered rear parcel, door panels. New power window switches, RSR door handles etc New Steering wheel. New audio speakers (rear, door, and dash) + vintage (modern) audi head unit from retrosound New dashboard (original was un-salvageable) New safety belts New front windscreen and rear windschield rubber seals You get the picture...basically everything aside from roof All work done by myself. Newbie to the world of Porsches, but not to DIY...so i factored in approx 10% margin on errors (which i made a few)...and right now, I am sitting on roughly $7.5k Hope this helps. I have read some folks spending 3k...but i question how thorough or complete the redo was. |
More likely ...i have not been as resourceful and frugal as you! |
I'm feeling lucky, only few bits of surface rust on the floor/tub. Few dings from improper jacking/lifting but they are easily fixed. Now to find new drain plugs. WTF are these for? The seam sealer is like rust magnet and I guess they never heard of a wet vac when adding this to the design? ![]() Paint options with rust help? Wurth GM vs other sound insulation (I have some dynamat left from RV install any reason to now use not that?)
