My other ride is a C-130J
RNajarian's Avatar
Crush washers on AN fittings?
I'm in the process of getting the necessary hardware to install a fender mounted oil cooler. At two points I will be joining a male AN12 fitting to a female AN12 fitting.
Is it recommended to put a crush washer (or any other type of washer) between them?
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 09-28-2015, 05:16 PM
Oh Haha's Avatar
No washers needed on AN fittings.
Pacific Blue
Wayne
Old 09-28-2015, 05:24 PM
RNajarian's Avatar
Thanks! That means I have everything I need
Old 09-28-2015, 05:34 PM
New-ish 911SC Targa Owner
pampadori's Avatar
The flares on the fittings are what seal. They are cut at 37° on one and just a touch more than -37° on the other. As the fittings are tightened they come into one another and seal extremely well.
AN and JIC are basically the same except for the material and tolerances on AN are a touch better/tighter.
I always smirk a little when I see AN or JIC fittings connected with plumber's tape on the threads. No flare fitting ever required it for a seal.
Old 09-28-2015, 05:49 PM
Being in aviation for the last 20+ years, I can tell you that there are rare instances where you will see an aluminum crush washer used, but usually in a fuel application. On our cars however, it's not needed for the exact reason that RNajarian pointed out.
Old 09-28-2015, 11:25 PM
Chain fence eating turbo
They have a 37° cone not requiring a washer. IIRC, standard flared fittings for general run 45°.
My understanding from tech school was to prevent non-aviation grade fitting from being attached.
Old 09-29-2015, 04:12 AM
Navin Johnson
TimT's Avatar
In cases where a fitting is buggered up, and you have problems getting a leak free joint there are solutions... New fittings... no washer...
Seco seals from Pegasus
'69 911 GT-5
'75 914 GT-3
and others
Old 09-29-2015, 02:42 PM
gtc gtc is offline
abides.
gtc's Avatar
Probably the same people that insist on new washers and nylock nuts on valve covers so they don't leak...
Graham
1984 Carrera Targa
Old 09-29-2015, 02:49 PM
