85 Carrera shock recommendations
Winter project is to replace the original shocks on my '85 911. I'd like to keep the current stance (Height). Any recommendations on brand and type. If I can improve handling a bit I wouldn't mind but I don't want a kidney killer.... I don't track the car. Should i also do a sway bar upgrade? Any advice is appreciated.
BTW, I think I have Boge in now.
Old 11-14-2002, 12:05 PM
Most go with the Bilstein HD or Sports. I used the heavy duty up front and sports in the rear. Ride height did change despite that many folks say it will not. The ride is very tight but not too rough, although I now constantly ***** about the crappy roads in the US.
Randy
'87 911 Targa
'17 Macan GTS
Old 11-14-2002, 01:28 PM
Senior Member
Superman's Avatar
I just noticed that Monroe shocks are on sale at Sears for under $18. Those will work nearly as well as a Bilstein that has been over the Baja 1000 race course a hundred times.
Mocha 1978 911SC. "Coco"
Old 11-14-2002, 01:33 PM
D idn't E arn I t
RANDY P's Avatar
Simplest solution is to stick to the brand you have now. Upgrading to Bilsteins or Koni's, or changing brands requires new strut housings in the front.
But of course if price isn't an issue, anything goes.
rjp
AOC/Hogg 2028
Old 11-14-2002, 02:47 PM
Irrationally exuberant
ChrisBennet's Avatar
I believe your '85 will have Boge struts for which Bilstien inserts are available. I have Bilstien HD's all around and they are comfortable. Gas shocks like the Bilstiens will raise the car so you will have to reset the right height and align the car when you are done.
-Chris
Old 11-14-2002, 05:04 PM
