IMR-Merlin's Avatar
Red face G50 Rebuild Manual
Anyone know if there is and/or where I can find a rebuild manual for a G50/00?
I have some input shaft issues and I need to pull it apart to take a look.
Brendon
Old 07-10-2015, 04:43 AM
IMR-Merlin's Avatar
guess I am looking for one of these
Old 07-10-2015, 05:03 AM
Have you ever done a transmission rebuild? A G50 is not impossible, but it's not a good tranny to learn on.
It's maybe 50% harder than a 915.
Old 07-10-2015, 08:39 AM
IMR-Merlin's Avatar
yeah, mostly crash boxes in motorcycle and some Formula Fords when i was at Skip Barber.
Old 07-10-2015, 09:40 AM
KTL KTL is offline
Schleprock
KTL's Avatar
You could use the 993 factory Porsche manual as a guide if you're just taking it apart for inspection. The 993 6 spd is generally the same as the 5 spd. Generally same enough for partial disassembly. PM me and i'll give you a copy of the 993 manual via email.
Kevin L
'86 Carrera "Larry"
Old 07-10-2015, 10:01 AM
IMR-Merlin's Avatar
PM sent, I basically need to pull the cases apart and see what I need for pullers in the manual. I am mainly interested in the bearings for the input shaft.
We have isolated my issue to the bellhousing trans area.
slight rap @3k (Tensioners?)
Old 07-10-2015, 10:17 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Sent you a PM back and linked/shared you to my Google Drive file hosting
For pulling gears you need a really long puller. A local friend built a few G50 gearboxes and the really long puller and a really long socket (basically a tube with a socket welded onto it) were needed to work on the G50
Kevin L
'86 Carrera "Larry"
Old 07-10-2015, 10:21 AM
The puller is fairly easy to make, just longer bars for a FLAPS puller.
But the G50 is a challenge.
I found the G50 info in a 911 manual, it was 1984-1989 I believe, so it had G50 and 915.
Old 07-10-2015, 11:15 AM
Do you have a work email that can accept large file? PM me if you do.
Old 07-10-2015, 11:16 AM
IMR-Merlin's Avatar
if it's in the Bentley Manual, I think I have the 84-89 somewhere.
Old 07-10-2015, 11:36 AM
Diss Member
Quicksilver's Avatar
Bentleys doesn't cover it. The factory manual has it mixed in with the 915 stuff. (I discovered that my manual was missing pages when I went through this.)
I found that the WKS 303 021 manual is pretty much impossible to find. It is actually the training booklet for the P30 certification for Porsche training. I really would like a copy too...
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 07-10-2015, 12:10 PM
I have it if you can take a big attachment.
Old 07-10-2015, 01:13 PM
IMR-Merlin's Avatar
I will PM you my Email address. Not sure what my limit is.
Just checked my Bentley and it is NOT in there. Only covers 915.
Old 07-10-2015, 02:07 PM
KTL KTL is offline
Schleprock
KTL's Avatar
I have an '84-89 factory microfiche that has G50 repair info in it. It'll take me until next week to print it out on my work's microfiche machine and then scan it.
Kevin L
'86 Carrera "Larry"
Old 07-10-2015, 02:12 PM
IMR-Merlin's Avatar
If you can do that, it would be very helpful. I am doing valve adjustment and full service on an SC that I bought this weekend and I might hold off on doing the G50 till after I get it back from Turbopalooza. I just hope it makes the trip.
Old 07-10-2015, 02:54 PM
Sent.
Old 07-10-2015, 03:48 PM
KTL KTL is offline
Schleprock
KTL's Avatar
My fiche for 84-89 Carrera, is dated June 1990, and has about 60 pages of service/tech info on the G50. If any of you guys want to take a look at it, I uploaded it to my google drive. Send me a PM with your email address and i'll put you on the share list.
Kevin L
'86 Carrera "Larry"
Old 07-16-2015, 02:58 PM
IMR-Merlin's Avatar
I got everything guys. After some digging through all the drawings I think it's one of the 2 engine side bearings on the input shaft... I'll know for sure when I pull apart in a few weekends.
Thanks for everything!!!
Old 07-16-2015, 03:24 PM
IMR-Merlin's Avatar
I am bringing this post back from the dead. I had someone Email me a link to their drop box and I lost the file with a hard drive failure.
82 twin plugged, EFI, G50 930, RSR suspension (soon to be) GT35R...
Old 10-09-2015, 01:37 PM
Do you want me to resend? Or someone else?
Old 10-09-2015, 03:56 PM
