-   -   Anyone have a picture of a 79 fuse block (http://forums.pelicanparts.com/porsche-911-technical-forum/874418-anyone-have-picture-79-fuse-block.html)
IMR-Merlin 07-12-2015 06:20 AM
I have the 84-up Bentley here but nothing for a 79.
Someone really dug deep into my 79's wiring trying to "fix' a no start issue. I have found the original cause (hidden kill switch) but now need to undo all the other problems.
There is all sorts of bad things done to this poor fuse block and I would really appreciate a picture of an unmolseted one to make sure the wires go back in the right spot.
Thanks in advance
Brendon
86 911 Targa 07-12-2015 09:33 AM
Fuse Block.
Thanks in advance
Brendon
https://www.google.com/search?q=1979+911+PORSCHE+FUSE+BLOCK&rlz=1T4GUEA_e nUS570US570&tbm=isch&tbo=u&source=univ&sa=X&ei=1Ze iVdj1OI3VoATKjb_YDQ&ved=0CD8QsAQ&biw=1140&bih=715
Here
IMR-Merlin 07-14-2015 08:04 AM
I am actually looking for a physical picture of the box installed in the car with wire colors going in and out of each fuse location from a US 79 SC so I can try to get this car back together and running correct.
Someone did some real good messing around with the wiring in an attempt to get the car running because they didn't know where the PO hid a failed kill switch...
anthony 07-14-2015 08:12 AM
How can you trust someone's picture? I thought my 90k mile car was relatively unmolested but I'm finding a few inconsistencies in my fuse panel. Some has been in there for some reason.
IMR-Merlin 07-14-2015 08:22 AM
True but it will get me in the ball park for a few things, then i can sort the rest out.
Beats the guess work while I wait for my mid year Bentley to get here. Mainly on the hot side of the fuses.
Jim Savage 07-14-2015 09:54 AM
76 911 Before restro
http://forums.pelicanparts.com/uploa...1436892839.jpg
BlueWing 07-14-2015 10:29 AM
Might not be a big help but this is from my 79 ROW. I added a 3 fuse block to the far left to fuse the dimmer/directional stalk control for the high/low beams and 2 relay sockets to the far right for the high/low beams (relay for low beam was not in place thus empty socket). The rest appeared original before my additions.
Not sure if any will apply to your USA 79 but maybe get you started.
Terry
http://forums.pelicanparts.com/uploa...1436894957.jpg
IMR-Merlin 07-14-2015 11:45 AM
I already printed this picture off from another thread!!! LOL
Terry
OsoMoore 07-14-2015 12:52 PM
My 79 had some modifications by a previous owner. I took extensive notes, took the fuse box apart, and built a new setup with modern ATO fuses. I can link you my notes - maybe it will help.
OsoMoore 07-14-2015 12:54 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/810035-sick-time-update-my-sc-fusebox-2.html
Good luck!
evan9eleven 07-14-2015 01:27 PM
The original panel in my '81 SC before I replaced it with a Fred Cook panel. Not sure the pic helps as its not totally original but close. Number 21 on the far left is missing (power windows) while 19 and 20 are A/C. Good luck!
http://forums.pelicanparts.com/uploa...1423840477.jpg
timmy2 07-14-2015 01:34 PM
Just download the '78 schematic from Pelican. It is the same.
http://www.pelicanparts.com/911/911_Parts/911_electrical_diagrams.htm
Jonny H 07-14-2015 01:37 PM
Our offering if it suits you. 50+ installs so far.
http://forums.pelicanparts.com/porsche-911-technical-forum/870742-new-company-new-products-classic-retrofit-911-fuse-panel-cdi-ignition.html
IMR-Merlin 07-14-2015 02:56 PM
Originally Posted by Jonny H (Post 8710303)
I've seen your work and the other ATO swaps. Nice work and thanks for reaching out but I am trying to not make this a project car. I already have my EFI 930 with a custom harness in it.
I want to get this back to as original as possible for resale.
Brendon
