I have the 84-up Bentley here but nothing for a 79.
Someone really dug deep into my 79's wiring trying to "fix' a no start issue. I have found the original cause (hidden kill switch) but now need to undo all the other problems. There is all sorts of bad things done to this poor fuse block and I would really appreciate a picture of an unmolseted one to make sure the wires go back in the right spot. Thanks in advance Brendon |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Fuse Block.
^^^^^ Here
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 07-12-2015 at 09:37 AM.. |
I am actually looking for a physical picture of the box installed in the car with wire colors going in and out of each fuse location from a US 79 SC so I can try to get this car back together and running correct.
Someone did some real good messing around with the wiring in an attempt to get the car running because they didn't know where the PO hid a failed kill switch... |
How can you trust someone's picture? I thought my 90k mile car was relatively unmolested but I'm finding a few inconsistencies in my fuse panel. Some has been in there for some reason.
Beats the guess work while I wait for my mid year Bentley to get here. Mainly on the hot side of the fuses. |
76 911 Before restro
Might not be a big help but this is from my 79 ROW. I added a 3 fuse block to the far left to fuse the dimmer/directional stalk control for the high/low beams and 2 relay sockets to the far right for the high/low beams (relay for low beam was not in place thus empty socket). The rest appeared original before my additions.
Not sure if any will apply to your USA 79 but maybe get you started. Terry
79 SC Minerva Blue ROW Non Sunroof Crank Window Coupe 3.0 SSIs, Backdated Heat COA: Passenger Side Mirror, Manual Antenna & Dunlop Tires |
I already printed this picture off from another thread!!! LOL
My 79 had some modifications by a previous owner. I took extensive notes, took the fuse box apart, and built a new setup with modern ATO fuses. I can link you my notes - maybe it will help.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go! |
The original panel in my '81 SC before I replaced it with a Fred Cook panel. Not sure the pic helps as its not totally original but close. Number 21 on the far left is missing (power windows) while 19 and 20 are A/C. Good luck!
1981 911SC restomod "Minerva" 2004 Boxster S 2021 Cayman GTS 4.0 manual "Olive" 2014 Cayenne GTS V8 (wife's lover) The slope is not slippery; in fact it is entirely frictionless. |
ROW '78 911 Targa
Just download the '78 schematic from Pelican. It is the same.
http://www.pelicanparts.com/911/911_Parts/911_electrical_diagrams.htm
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 07-14-2015 at 01:42 PM.. |
Our offering if it suits you. 50+ installs so far.
New company and new products. 'Classic Retrofit' 911 Fuse Panel and CDI+ ignition. |
I want to get this back to as original as possible for resale. Brendon |
