Help design my a/c hose routing
1980, converting to 134, need all new hoses.
I have an underbelly, decklid and front condenser.
Will not be switching to any new brands. all of the condensers/evaporator/compressor are in good shape. Only moving hoses.
I hoped to just repair the hoses I have, but it turns out that the system that the PO put in about 10 years ago was NOT barrier hoses, like I thought (the crimps run along the hose, not perpendicular to it). So, need all new hoses, which is fine (some are damaged, some are old, some are going to be too short, etc, so wwest, you can keep your "barrier hose is useless" stuff to yourself).
I would consider adding a handbuilt condenser in the front driver's wheelwell. Don't exactly want to, but would consider it.
So, give me some ideas. The current routing is compressor-underbelly-decklid-front-dryer-evaporator-compressor.
Options I've considered:
1) underbelly-decklid-front
2) decklid-underbelly-front
3) REVERSE THE GAS
4) add a wheelwell, go underbelly-wheelwell-front and delete the decklid
5) add a wheelwell and go all out, decklid-underbelly-wheelwell-front
Or, delete the front and add a wheelwell, which opens up a future IROC bumper or oilcooler or something.
I'll be making all my own hoses and doing my own charging, so some experimenting is an option. SOME experimenting, mind you...
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 07-13-2015, 09:08 AM
El Duderino
tirwin's Avatar
Oh, lordy. You're just asking for it aren't you?
I would think Option 2 would be the shortest in terms of hose routing.
Having recently pulled new hoses, one thing to keep in mind is that you just want to make sure you maintain ground clearance.
Has your system worked at all since you've owned it? If so, would you say that the cooling capacity was sufficient? That should give you some general indication of whether you need to increase condenser surface area or not. Then next things to consider would be the effect of increasing evaporator surface area and fan speed.
Now that the pin has been pulled on this grenade, I'll take a step out of the blast radius.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 07-13-2015, 09:57 AM
wwest's Avatar
I have NEVER taken the position that barrier hoses are "USELESS".
My position has been that by restricting the high side pressure to limited range the non-barrier hoses will not leak, most especially post conversion to R-134a. And as you know both the US Government and Dupont support that latter position.
3) REVERSE THE GAS
Ask Charlie what he thinks of this...
6) eliminate the underbelly... subject to debris and radiant roadbed heat, add the fender well blower/fan. Front fender most desireable, only radiant heat source would be the tire, and you could run the fan(s) from a thermostatic switch on the R/D just as Porsche did with some models.
My only direct experience with the underbelly condenser is having purchased a '79 Targa in Salt Lake. A/C thermostatic switch had failed and upon repair I was advised that the belly condenser had been bypassed.
Contacted the PO who said the underbelly condenser seemed to work fine in NJ where he lived previously, but was advised that the poor performance in SL was due to the lack of efficiency of the underbelly condenser.
He said that after bypassing the underbelly condenser he felt the A/C worked better.
If it is true that the belly condenser is no longer available there might be good reason.
NJ vs Ut..???
Old 07-13-2015, 10:03 AM
French Import
zippy_gg's Avatar
3) REVERSE THE GAS
I'd say option 1, which in essence is very similar to "reverse the gas" since you are not dumping all the heat in the decklid and the engine. Keep your current setup if you are happy with the cooling it provides. If your compressor is in good shape you will only need to replace the R/D.
Can you share pics of your underbelly setup? How is it protected from the road debris (guard, etc...)?
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 07-13-2015, 10:15 AM
If you want to take Mr. Wests' advice and get rid of the underbelly, I'll be more than happy to take it off your hands. Every car I've ridden in that had it, had excellent a/c.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 07-13-2015, 11:13 AM
The underbelly condenser stays, the car had frighteningly cold air the first summer I owned it, but a mistake with the fitting on the compressor blew all of the freon out one day. Hasn't worked since, haven't put any effort into making it work.
The setup now involves loading the underbelly first, which will take heat soaking away from the engine bay, but involves probably 10 extra feet of hose. Not a huge deal, but something to think about. I daily drive the car, but i'm on surface streets in basic 30mph traffic, not stuck in gridlock. I know the underbelly is worthless when sitting still in Houston, but that rarely happens to me.
Do i need a new fender condenser? no, but if that could/would allow me to remove the decklid one, then it's probably well worth it. I have seen people mention running a fender system and removing the decklid stuff, but no actual reports of anything doing that (as a retrofit on an older car, of course).
Currently the underbelly has basically no protection(well 2 1/8th in straps that hold it in place). The fins are thick and after 10-12 years show no damage. Car is at Euro height.
I will probably stick with current route (belly-decklid-front). It's not the shortest run, but the routing is there now to follow, and any strain taken off of the engine temps is worth it.
Oh, I'll likely toss a fan in the decklid, because there's room and it won't hurt.
Mike Bradshaw
Old 07-13-2015, 11:36 AM
Brando
quattrorunner's Avatar
I Have an underbelly unit, I've been looking at using it for years and still haven't installed it but will. I've read soooo many good testimonials with it that I just want to use it. BTW if you've ever seen one you'll see that it's not that vulnerable. It's stout to say the least. The fins are thick, the lines are also thick. The whole thing can take a rock hit and keep pressure by the look of it.
But, the fender units with fans make perfect sense and the latest AC thread that hoteuro shows only one decklid condenser system shows that three condenser systems are silly. Get a good condenser or two and be done with it. The hoses you're replacing will go a long way too.
I'm pulling for you, I'd bet you'll have a great system once all buttoned up.
I'll be watching this one with interest unless it gets too heated and if that happens, I'll just do like I always do and hide in the turbo/930 section for a while.
Turbo powa!
1977 911s. it's cool
Old 07-13-2015, 11:56 AM
ganun's Avatar
Mike If you can, please post a pic of that underbelly, how big is it? And...
If at some time it was "frighteningly cold" then it sounds like you answered your own question.
87 911 coupe, GP white, cashmere/black
64 Alfa Romeo Giulia TI - the violin
89 Peugeot 505 Turbowagon-other Pcar
67 912 coupe, white, sold
04 Audi Allroad 2.7T
Old 07-13-2015, 12:01 PM
With making up new AC hoses, there are the newer, smaller diameter barrier AC hoses available. You are most likely aware of them, but if not, they are a lot smaller diameter and much easier to run thru the chassis. I had some new barrier hoses made up for my
car at a local industrial hose/fittings company, unfortunatley they didn't inform me of the smaller hoses till mine were already made up. Drat the luck!!
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 07-13-2015, 01:14 PM
I won't let this thread become a CF. I will make sure to have Red-Dot brand trinary switches on both ends of the car feeding their respective Spal fans. I will not drive without removing the heat soak from the passenger area by opening all windows first. I will get the darkest legal tint for my sunglasses. I will crystallize the windows with heat rejecting crystals. I will remember that I am an uneducated redneck Texan
Mike Bradshaw
Old 07-13-2015, 01:22 PM
They are an option, at least the the reduced #8 hose is. It uses the same crimping dies as the normal #6 hose, so I thought I might use normal #6, reduced #8 and a single run of normal #10. Instead of buying extra dies at $70 each.
I will say that the reduced hoses are only about 20-25% smaller, and since I'm replacing good old fashion R12 hoses, the routing shouldn't be much of a problem.
Mike Bradshaw
Old 07-13-2015, 01:25 PM
wwest's Avatar
Given that the "first in line" belly condenser obviously works so well for you I wouldn't hesitate adding a condenser/fan in the front(***) of the rear wheelwell and remove the rear lid condenser once the new configuration has proven itself.
On the other hand if you should add the fender mounted condenser/fan it might be wisest to make the new, more efficient (forced air cooling)condenser/fan "first in line".
Short hose runs to boot.
*** The radiant heat from the exhaust/engine/catalyst may well be so minimal that it only has a 5-10% negative effect but why bother since the alternative is readily available.
Old 07-13-2015, 01:28 PM
Brando
Here are two.
Turbo powa!
Old 07-13-2015, 01:35 PM
El Duderino
tirwin's Avatar
OK... someone has to say it...
Old 07-13-2015, 01:37 PM
I actually wanted to go into the front of the front wheelwell, where the washer bottle is. That way, the flow path would be very direct, compressor-underbelly-fender-front-dryer-evaporator. The hoses would "mirror" the oil lines under the edge of the car.
I've also been looking at bulkhead fittings for A/C o-ring fittings, and wondering if there is any routing that might be easier going through the frunk...
Mike Bradshaw
Old 07-13-2015, 01:38 PM
Originally Posted by quattrorunner View Post
Here are two.
Mine looks like the one of the left. About 3/4 thick total, with the shield endcaps like that. It runs almost to the oil lines left-right, and, what, 18 inches front to back?
Mike Bradshaw
Old 07-13-2015, 01:39 PM
Brando
These are identical just one is turned around
Turbo powa!
Old 07-13-2015, 01:47 PM
Forced perspective made the one of the right look about twice as thick.
Mike Bradshaw
Old 07-13-2015, 01:49 PM
I wonder why they quit making them? The sheer size of them makes up for any inefficiency. The ones I've seen look like they are steel. Is that so?
I think it was Performance Aire that sold them.
1991 C2 Turbo
Old 07-13-2015, 03:12 PM
El Duderino
tirwin's Avatar
Not sure why they quit but I wouldn't want one because I don't need anything hanging any lower below the car. Seems like road debris and snagging on speedbumps is a possible downside.
Old 07-13-2015, 03:38 PM
