wrxnofx's Avatar
CV Joint Removal and Wear Questions
I noticed this past Summer that my passenger inner CV joint boot was split and leaking grease. Today I got around to removing it (first timer).
So, long story short, after removing removing the 6 bolts, removing the end cap, removing the snap ring, removing both clamps, and pulling the boot back, I could not get the joint off the axle spline just by pulling it off. I had to tap it off the spline using a brass punch on the star shaped part. Problem is, evidently the star shape at the center of the CV is made from brass, too. Good to know. So now the star piece is dented and, worse yet, the edge of the grooves the balls travel on are "bent" at the top, forcing me to have to replace it. Here is a pic:
So, first question is, how in the hell are you supposed to get a CV joint off the axle shaft without damaging it?
Second question is, I think this joint was shot anyway given the wear. Please tell me that's the case so I'm not as mad at myself for damaging it. The balls themselves are fine, but the other two parts are worn:
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 01-09-2016, 10:38 PM
Racer
winders's Avatar
Are you sure you used a brass drift punch? The inner race (star) is made out of some type of hardened steel and will not deform when brass drifts are used. I know because I just rebuilt all four CV joints on my race car and they all use standard GKN parts. I had to bang really hard on 3 of them with a brass drift. The star has to be as hard as the outer race. The cage is made out of a different material.
The wear looks reasonable. The cage always seems to have the most wear and the wear in the photo does not look too bad. When you run your fingernail over the wear points on the outer and inner race, do you feel a valley at the shiny points or is it just smoother than the surrounding steel?
I don't like using the grease that comes with the GKN kits. I use Red Line CV-2 instead with MUCH better results.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 01-09-2016, 11:37 PM
Yes you should replace the joint as it is worn - mildly.
You have to buy a new boot anyway, so order a kit with both boot & joint in it & grease/gaskets.
Read the posts about the bolts coming loose after installation and decide if you want to use thread-locker goo on the bolts.
Good luck - its one of the easiest 911 repair jobs.
Old 01-09-2016, 11:44 PM
Almost Banned Once
sc_rufctr's Avatar
I'd use them as is. Polish off the damage and go for it.
These cars are really well engineered. I think we forget that sometimes and things are replaced before being fully worn out.
- Peter
Old 01-10-2016, 03:37 AM
michael lang's Avatar
I agree with Scott and Peter, clean and polish it, put it back together, pack the hell out of it with cv grease and put the new boots on. Mine were in similar shape a few years ago, six track season later, still sealed up and quiet.
Mike
'89 CARRERA
#402
Old 01-10-2016, 05:21 AM
I replaced the boots on the left driveshaft this past fall. First time for me too. Took the shaft completely off to make the job easier. Stop banging on the CV joint, people. Use a gear puller to move it gently off the shaft. You can get a cheap one for $10 or so. If I recall, I had to put a couple of bolts on the joint to give the puller something to latch on to as its arms weren't wide enough to reach around the joint. Using a vise when playing with these messy things helps tremendously. I also remember using a bit of duct tape on the joint as soon as I disconnected it from the transaxle to keep the joint from falling apart between the car and the vise. Will do the right side in the Spring.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 01-10-2016, 06:03 AM
Clean it up, grease it, and run it. If it does not make noise, it's ok. If it clicks, replace it. I've probably done this to 100 or more joints, lost count. Dave
Old 01-10-2016, 06:21 AM
Racer
winders's Avatar
Make sure you assemble the CV joints as described here:
http://www.californiaperformance.com/cv_assembly.htm
Scott Winders
PCA GT3 #3
Old 01-10-2016, 11:11 AM
wrxnofx's Avatar
Yup, absolutely a brass punch. Hence my surprise that something so soft would dent the CV joint.
Old 01-10-2016, 11:15 AM
wrxnofx's Avatar
This forum never ceases to amaze me. Thanks for all the replies, everyone.
I'm leaning towards re-using this joint. I didn't know what was considered excessive wear versus mild wear, and now I know.
However, the one area of concern is one of the ball tracks. Evidently I got careless with where the brass drift was placed on the star when tapping the joint out, and I got it near the edge of one of the ball tracks, which mushroomed the top edge:
I should be able to just file it smooth I would expect. What say you?
Old 01-10-2016, 11:22 AM
Functionista
manbridge 74's Avatar
Small round or half-round file and done....
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 01-10-2016, 11:27 AM
Racer
winders's Avatar
Yes, file it smooth. The ball will never get up that high anyway.
Scott Winders
PCA GT3 #3
Old 01-10-2016, 12:49 PM
patz's Avatar
Buy a new set of axles and CV joints. The rebuild is a nasty job. Contact Eric at www.pmbperformance.com .... plug and play.
Old 01-10-2016, 01:12 PM
The half-shafts for my C4 are stupid expensive, so I sent them all to CV of Ocala (FL) for a rebuild. ~$150 each, they polish the ways (not grind) and replace the balls with ones slightly larger.
Very happy with the results.
'90C4
Old 01-10-2016, 01:25 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Reconstructing Constant Velocity (CV) Joints
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 01-10-2016, 02:08 PM
If you ever have any trouble getting it off the shaft, Autozone and I am sure other stores have loaner tools. I used a puller on 3 of the 4 joints. Dirty job. Steve
1970 911T SOLD
1989 3.2 Carrera
2013 991 Carrera S
Old 01-10-2016, 02:10 PM
wrxnofx's Avatar
So, instead of a $10 fix (boot kit from our host) or at worst, a $71 fix (CV joint from our host), you would spend $310 on a whole new axle? Actually, you said a SET, so $620 vs. $10. I guess that's one way to do it.
Old 01-10-2016, 03:11 PM
patz's Avatar
Do what you want. I have a warranty and no issues. Advice is free.
Old 01-10-2016, 03:15 PM
Spiderman
Jesse16's Avatar
I would rebuild them. These are very robust parts and the angles they operate at are reasonably slight. Just keep things clean during the rebuild. If like my 87, you cannot easily take the outer end apart. I had damaged outer boots and cleaning that end with the parts still together is the only difficult step.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 01-10-2016, 04:00 PM
Bulldog9's Avatar
My 76 had large circlips and an a beveled washer holding the joint on the shaft.
1976 Porsche 912E http://www.912bbs.org/vb/showthread.php?43391-770-Update
1989 Porsche 944 S2
2020 Mustang Bullitt
Buncha Moto Guzzi Motorcycles
Old 01-10-2016, 10:34 PM
