-   -   Help me verify my timing procedure, 1981 911SC (http://forums.pelicanparts.com/porsche-911-technical-forum/875562-help-me-verify-my-timing-procedure-1981-911sc.html)
Kemo 07-20-2015 12:16 PM
after researching, this seems to be the procedure for ignition timing on my 81 SC, I think.
1. pull the vacuum hoses to distributor and clamp them shut
2. set the timing at 5 deg BTDC at 950 RPM
3. reconnect the vacuum hoses and adjust idle back to 950
After performing this, I did a quick check with the timing light and after reconnecting the hoses, the car's timing had retarded quite a bit to the left of the Z1 mark. Just guessing, I would say about 5 or 6 degrees. Is this normal?
Thanks!!
Flat6pac 07-20-2015 12:29 PM
Yes, that's the vacuum retard side working for emissions. Pull that backside line and the idle will come up to the 5 BTDC.
Bruce
