Black and Blue
Help me verify my timing procedure, 1981 911SC
after researching, this seems to be the procedure for ignition timing on my 81 SC, I think.
1. pull the vacuum hoses to distributor and clamp them shut 2. set the timing at 5 deg BTDC at 950 RPM 3. reconnect the vacuum hoses and adjust idle back to 950 After performing this, I did a quick check with the timing light and after reconnecting the hoses, the car's timing had retarded quite a bit to the left of the Z1 mark. Just guessing, I would say about 5 or 6 degrees. Is this normal? Thanks!!
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
Yes, that's the vacuum retard side working for emissions. Pull that backside line and the idle will come up to the 5 BTDC.
Bruce |
