-   -   Starter troubles - no starter, why? (http://forums.pelicanparts.com/porsche-911-technical-forum/875779-starter-troubles-no-starter-why.html)
gjmascoli 07-22-2015 05:15 AM
After reinstalling engine 4 months ago after my first engine drop I had no starter. Starter seemed fine before the drop, but it was original, so I replaced battery and starter and was back I business.
Last month, after daily driving for a few weeks, the starter went intermittent, I.e. Turn the key and get all systems on, but no starter. Had to pop start a couple times so as not to get stranded at work. After a few incidents I decided to replace the ignition switch. Did that Sunday and back in business. Drive Sunday, several starts and stops, no prob. Drove to work Monday and Tuesday, no prob.
This morning, NO STARTER. Turn key, all systems go, but starter doesn't engage.
So: New battery, starter, ignition switch.
Ideas? Bad solenoid on new starter? Loose wire? short?
How to troubleshoot?
McLaren-TAG 07-22-2015 05:22 AM
I'd start (if you haven't already done it and are 100% sure they're fine) with redoing all of the ground connections as well as the stater cable at both ends. I'd also no overlook the stupid things, like perhaps an 80's alarm that wasn't completely removed that's left a failing starter kill switch/relay somewhere in your car.
gjmascoli 07-22-2015 06:05 AM
OK. This is a '76S, no alarm system, so I can put that worry aside.
I'm not very good at electrical gremlins, but I can check the grounds. I do have a new transmission-to-chassis ground strap to install because the originalis all freyed - perhaps that is the root of the problem, but prolly wishful thinking.
Perhaps related: my Tach also stopped working with the engine re-install, and I am also thinking that is ground related, hence the new ground strap.
964TargaC2 07-22-2015 06:37 AM
When mine did that it turned out to be the wire from ignition switch to starter solenoid, it had a break in it somewhere, never found the break but ran a new wire and no issues since
GH85Carrera 07-22-2015 06:42 AM
If everything was working fine with the starter before the engine drop, it almost has to be a grounding problem. The big ground strap on the transmission is for sure something to be 100% sure is solid. There are several grounds on the engine. Make sure they are all solid.
If it continues, then start checking the other issues.
al lkosmal 07-22-2015 06:52 AM
+1 on the ground strap. To check mine, i once used my jumper cables to connect from the ground point by the battery to the starter body. (connected my jumper cables to each other to form one, long jumper) Started right up and proved that the ground strap was the issue.
regards,
al
Curt K 07-22-2015 09:02 AM
+2 on ground strap. I had a grinding issue, gone after replacing ground from transmission to body.
gjmascoli 07-25-2015 10:52 AM
Ugh.
OK, the transmission ground strap was pretty crappy, replaced with a nice solid new one from our host, but still no dice. Turn the key and hold in the start position, I can hear the fuel pump hum and all other electricals work, but nothing from the starter. No clicking of the solenoid, etc.
Connections to starter seem solid.
So, what are the mossible ground connects that I may have messed up or missed when I reinstalled the engine after the drop?
Is there diagram showing the ground points throughout the car? I have the current flow diagram, but that doesn't help me with where to look.
Help please :-(
timmy2 07-25-2015 10:56 AM
14 pin connector at the rear of the fuse panel is where the yellow solenoid wire makes its final connection before the starter. Check for corrosion or a loose connection there.
Pin one is the yellow wire.
If you have a meter and someone to turn the ignition switch to crank, you could test to see if the yellow wire at the male number 1 pin of the 14 pin connector is getting voltage when you crank.
Bob Kontak 07-25-2015 11:56 AM
+1 I remember reading Permatune's website for trouble shooting and they stressed checking this connection. Not for the yellow wire, of course. They warned about power washing the engine and getting water in there.
Also pins (male or female) can push back and it is hard to notice. Given this has been unplugged and recently plugged back in worth a look.
yelcab1 07-25-2015 12:07 PM
You need to attach a DVM to the solenoid wire, have a helper crank the key over, and observe what voltage you have. If it is >10V, and no start, you have a bad starter. If it is less than 5V, you have a break in the wire. Very likely the 14 pin connector pin is bad or broken.
gjmascoli 07-25-2015 12:36 PM
Thanks Dennis, Bob, and yelcab1.
I cleaned up the very minor corrosion on the pins, including pin 1 (naturally it had more corrosion than others, but really not too much). Tried starter, no dice.
Connected an analog volt meter between pin 1 and its female socket in the 14pin connector. Had positive (+) VM lead connected to the pin and negative (-) connected to the female socket in the 14pin connector.
With the 14 pin connector DISCONNECTED except for the line between pin 1 and socket 1 I had a helper turn the key to start positon. No Voltage, No current showing on the VM. I didn't ttry to touch the (-) to the body to see if my problem is the yellow wire from the 14-pin connector to the starter. Lemme go try that.
Yelcab, what is the correct method of connecting the VM to the yellow wire....kind of what I described?
rick-l 07-25-2015 12:39 PM
Voltage is a potential measured between two points. Put the negative lead on the engine and the + lead on the yellow wire.
gjmascoli 07-25-2015 12:56 PM
OK, checked it again, this time (-) negative lead on the engine and the (+) lead on the yellow wire. I got nothing.
REMINDER: the whole 14-pin connector is disconnected, except for a temporary lead between the 1-pin and 1-socket that I can tap the VM into.
So, do I have some screwy ground issue, or is the problem somewhere between the ignition switch and the 14-pin connector?
timmy2 07-25-2015 12:58 PM
All voltage references are normally to ground as Rick mentioned.
Positive wire on pin 1 and negative on ground, give it a crank to see if you have voltage.
timmy2 07-25-2015 12:59 PM
Were you on the male pin one attached to the fuse panel or in the female socket of the connector.
If the female one, you won't see voltage as it is only connected to the starter solenoid.
timmy2 07-25-2015 01:05 PM
Here is how the voltage makes it's way to the starter solenoid.
1. When key turned to start at switch 12 vdc is applied to the yellow wire. It runs through the 6 pin dash connector from the switch to a single spade connector that is part of the through body harness.
2. The voltage now travels directly through the through body harness to pin 1 of the 14 pin rear fuse panel connector.
3. Voltage now travels through the engine harness from pin one of the female engine harness 14 pin connector directly to the starter solenoid terminal.
gjmascoli 07-25-2015 01:22 PM
Dennis(timmy2)
I made the connection by:
1) disconnect the 14-pin connector
2) stick a long metal "pin" (actually a correct diameter steel nail) into #1 female socket in the 14-pin connector
3) run an aligator clip from male pin #1 to the "pin" that is inserted in 1 female socket
4) connect the (+) positive VM lead to the pin that is in 1 female socket
5) connect the (-) negative VM lead to the engine/body
So I have a hard connect between the #1 pin and socket.
If I was getting Voltage back to the connector,
THEN
if the yellow wire was broken between the 14-pin connector and the starter, that would explain the no starter
BUT
since I do not get any Voltage between pin #1 and the engine (or to the body if I move the ground connection) That seems to indicate I am not getting any voltage back to the connector and the problem is up front at the 6 pin dash connector or the single spade connector that is part of the through body harness.
Is my logic sound?
I think I came across the 6 pin connectors (there are three of them under the dash?) when I did the ignition switch.
Where do I find the single spade connector that is part of the through body harness?
timmy2 07-25-2015 01:29 PM
PM sent with my phone number. Call me and we can work through it easier if you want to.
timmy2 07-25-2015 01:39 PM
Get rid of the rod. Leave the female 14 pin harness off to the side.
You only are trying to see if power is making it to the male 14 pin terminal number one. (it is the last one on the bottom row closest to the fender)
Just touch the red meter probe to it and the black one to ground and turn switch to crank and see if you have a full 12 volts or more.
timmy2 07-25-2015 01:43 PM
Think of power flow as water through a garden hose. When you remove the female 14 pin connector you removed the next path for the power to flow, so it should be sitting on the male 14 pin connector pin one, ready to go through your meter to ground.
gjmascoli 07-25-2015 02:19 PM
Yep, got it��.
Lemme try again when I get home
rusnak 07-25-2015 02:57 PM
You can just check for 12v at the starter with the key on.
A quick check with a remote starter switch will tell you if it's the ground/ wire/ switch or the solenoid. If it's the solenoid, then you can either have it rebuilt or get a new/ reman starter and do an easy bolt in swap.
gjmascoli 07-25-2015 06:13 PM
Using my cheap Radio Shack Analog Multimeter.....
Voltage from Pin 1 to Ground is about 15V with the ignition in the Start position! Also getting 15V across the battery terminals. That is not good, right?
Reminder, battery and starter were replaced with new back in March / April'15.
Ned, NYNA11 07-25-2015 07:11 PM
Hi,Battery voltage is available always at the ignition switch and when you turn the key, the voltage is connected to the yellow wire which goes to a connector on the firewall nearby and the plug for the wire in that connector can be loose. This was the cause of the same problem in mine.
rick-l 07-25-2015 07:54 PM
Now do the same thing down at the starter. Car in neutral of course.
DaveMcKenz 07-25-2015 07:54 PM
I would reconnect your 14-pin and battery, and see if you get battery voltage on the yellow wire going to the starter with the ignition key in the start position. BTW 15V on your battery probably is due to meter error. If you get voltage on the yellow wire, you got a bad starter. It's probably a rebuild, but it probably has a warranty.
Good luck,
Dave
timmy2 07-25-2015 09:00 PM
Just pm'd you same instructions as others, time to crawl under the car and test for voltage at the starter. Disconnect the yellow wire lead to be safe and test it that way so the starter can't kick in if removing and re-seating the 14 pin connector solved the problem!
mhackney 07-26-2015 06:13 AM
Hello, I just recently had to diagnose a similar sounding issue on my 70S. Turn the key and the fuel pump comes on but no click from the solenoid and no starter motor. I check ground strap, voltages, pulled the ignition switch and checked it, etc. I was just in the process of learning the "bear hug" to remove the starter when I found a post that mentioned something about checking the voltage at the fuse box in the engine compartment. I did and it was quite low. Turned out to be a corroded terminal (yellow wire) in that 14 pin connector. Cleaned it up and it literally started up first time.
SpyderMike 07-26-2015 10:30 AM
As Dennis mentioned in 1 above, there is this connection behind the dash (yellow wire):
http://forums.pelicanparts.com/uploa...1437931786.jpg
Posted for possible future reference...
gjmascoli 07-27-2015 07:39 PM
Wow how dumb am I...............
Crawled under the car again tonight to check if I'm getting any power at the starter. Before I pulled the Yellow Wire off the spade on the starter I checked to see if it was loose. Not terribly loose, but I could move it pretty easy. Hmmmm, before I go any further lets see if the starter engages. Sure enough, started right up.
But I do thank you for all the pointers!
gjmascoli 08-17-2015 03:48 PM
Well, perhaps I wasn't so dumb afterall. So three weeks have passed and I quickly understood that my problem was not a loose electrical connection. The starter worked great for a couple days, then I was back to the intermittent no-start.
So, I decided to go and tap the starter with a hammer. She starts. Drive to work. No start. Pop start her in 2nd gear drive home. Next day, starts right up. After work, no start. Bang the starter with hammer that I now keep in the car, starts right up.
So, this cycle of start, drive, park, no start, bang starter, start, drive, park, no start, pop, drive, park, start, ad nauseum continues for three weeks.
90% of time the starter engages after I clank it with the hammer. Occassionally I have to go back for a second round and hit it harder.
Decided it was a poorly rebuilt replacement starter. Ordered another replacement under warranty. It came in today.
Before I go and swap out the starter..................is there something I have missed? Remember, I replaced the ignition switch with new last month, and that worked for a couple days, then back to the PITA intermittant issue. Also replaced the transmission to body ground strap.
