Poll: HP?
Poll Options
HP?
911tmaster's Avatar
Exclamation poll!
what do you think my engine will put out in HP? its going on a dyno soon and i just want to get some guesses. it has 2.2L T p/c's and a 2.4 crank. T cams. zeniths. bursch headers and steelpak exhaust, and crank ignition. i think it will be in the 150 or 155 range. it started with 125 and th crank should (so i've heard)add 25 HP with the 2.2L p/c's
Old 11-13-2002, 04:21 PM
CamB's Avatar
It is like a (slightly) higher compression 2.4T and I'm guessing slightly more than the 2.4T's 140. To be more precise, I'm guessing 125-130hp at the wheels.
I'm guessing it might crack 150hp (130hp @ wheels) if there was really good attention to detail.
Ooops, just remembered the 2.4T had MFI which seems to be good for 10hp.
Knock back my estimate by ~10hp.
I think 120hp at the wheels. But a nice smooth torqey motor.
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Old 11-13-2002, 05:10 PM
pwd72s's Avatar
Can I change my vote? I only saw the poll, not the thread...at the factory rating for my car, I voted...sorry if I messed up the %ages...I'd guess around 120-130...
Old 11-13-2002, 05:28 PM
Navin Johnson
TimT's Avatar
based on what info you are giving, I wouldnt guess more than the stock 2.2T, the Zeniths are restrictive, the bursh steelpack is a dinosaur.
The stroke of the 2.2 and the 2.4 is the same..never heard of a crank adding hp ( perhaps reducing losses though)
Unless you did some head work, you have a stock 2.2T with crank fire and non factory exhaust.......
Id say 135 if your lucky
'69 911 GT-5
'75 914 GT-3
and others
Old 11-13-2002, 05:40 PM
Warren Hall Student
Bobboloo's Avatar
The 2.2 has a stroke of 66mm. The 2.4 has a stroke of 70.4mm. This is the displacement difference of the two motors.
I'll guess 135HP
Bobby
Old 11-13-2002, 08:08 PM
911tmaster's Avatar
hmm....i need to get some webers!what else can i do to up the hp?
Old 11-13-2002, 09:10 PM
Warren Hall Student
Bobboloo's Avatar
I don't think Webers are really going to gain anything over the Zenith's. They're both 40mm carbs. Even adding a sport exhaust would probably give very little gain because your intake ports are 29mm. Outside of porting, more aggressive cams, or a displacement increase I don't see alot of area for improvement.
E cams might be a way to go but you might have to cut reliefs in the pistons. A 2.4E is 165HP if my memory serves. With carbs you would probably get around 155 to 160HP.
Bobby
Old 11-13-2002, 11:19 PM
Phoenix's Avatar
My 2.4T with L cams and 40 mm PMOs recently pulled 133hp at the wheel at roughly 6,400/6,600 rpm (rpm from memory).
I'm guessing you'll pull about the same.
As CamB said: it is a smooth and torqey motor
...Oliver
'73 911T: 2.9ltr w/ PMO EFI
Old 11-14-2002, 07:57 AM
911tmaster's Avatar
who are the guys thinking i'll get over 170 hp? woah 170+ would be great!
Old 11-14-2002, 08:48 PM
A Quiet Boom's Avatar
Bobby
Yes but 40mm is only the butterfly size the important size is the venturis, I don't remember what size the stock Zenith venturi is (26 or 28 I think) but I'm running 36mm on my 3.0 and the throttle response and power are fantastic. I don't know if a suitable venturi is available for a 2.4 or not the 36 would work but you'd lose some drivability I would think. Either way, properly tune Zeniths are a dream and a whole lot cheaper than swapping on a set of webers or MFI.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 11-14-2002, 10:08 PM
