Repairing Bosh H4 Headlights
Does anyone repair Bosch H4 headlights?
I just picked up a couple of H4's but a couple of the rubber adjuster plugs are split and I would like to repair them all before I put them in Thanks Lorne M
83 SC |
Go to ********, headlight trim.
Link https://www.********.com/m/mobilecatalog.php?ck[ID]=d0b5343f05bb2fe93a665129cd2ee3ea&ck[idlist]=d0b5343f05bb2fe93a665129cd2ee3ea&ck[viewcurrency]=USD&ck[PHP_SESSION_ID]=7r7dvkocsav1ju87at1bp04en0
Bavaria911 1970 911T w/ 2.4S 1971 911T Targa w/ 2.2 RG Member # 818 |
Thanks but I am not finding headlight trim area
Lorne M.
83 SC |
Look under, Body then headlight assembly, headlamp trim.
I used 4mm or 5mm silicone vacuum hose (I have both, don't remember which I used). Cut off about 1/4 inch, stuff it in the housing (I used a bit of soap to help, it's tight) then slide the adjuster arm "finger" into it. Very tight, worked great, and will probably outlive the rest of the headlight assembly now.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Thanks guys, now I will have to find another excuse not to finish this.
I have to say .......... this is a great forum Thanks again Lorne M
83 SC |
You would think that with these lights being so expensive someone would have found a source for all of the separate parts.
Come on really, $110.00 for headlight ring and the parts most of us need just to get the parts, if those parts are available with the headlight ring then we should be able to buy them without the ring. Just my rant for the day Thanks Lorne M.
83 SC |
